Hi all I started a camper build on a Htundai i800 earlier this week. Its the first one of these and is quite different to the other vehicles I convert as its rear wheel drive. So far I have removed all the rear seats and stripped out the flooring. Removing the seats was a real nightmare as the bolts holding them dowm protrude throught the floor so were really rusted plus the heads are really soft so round off as soon as you put any torque on them. The new ply floor and flooring are down, the rock and roll bed has been trial fitted and I have started making the units. The rock and roll bed is going to need modifying as there's not enough head room to sit in it due to the high floor. Cheers - mike
Apr 11, 2022 18:49:31 GMT
Hi all
had a steady morning on this today. All the lights in the roof are now fitted and the roof lining has been refitted.
I have made and fitted the the kitchen unit door so that's finished now.
Tomorrow morning should see me making the templates for the wardrobe end panels.
Cheers - mike
elfman
Apr 11, 2022 19:14:16 GMT
I've been thinking of one of these myself or a Merc Vito due to the RWD. Did you buy a kit to fit it out ? Will watch with great interest.
Apr 11, 2022 19:30:05 GMT
hi there
I make all the units myself. Most of the kits you can buy are poor quality and need profiling to suit.
cheers -mike
Hi all, have had a steady week on the camper. She's starting to come together now and the end is in sight. All the units are made apart from the wardrobe front panel and I have started the final fit out. I spent most of wednesday taking 75mm out of the height of the seat as there was virtually no head room, its better now but still snug. I'm away later for a week on my boat so no updates for a while. Cheers - mike
hopeso
Apr 15, 2022 16:07:00 GMT
Any more pictures of your narrow boat? Did you fit it out yourself?
Hi there
I will sort some pics out when I get a moment. I didn't fit it out though I have made lots of improvements.
Cheers - mike
Apr 26, 2022 12:57:05 GMT
hi all got back onto this yesterday. I made and fitted the kitchen worktop and did the final fit of the kitchen. Spent most of this morning wiring up the 12v system so that's now finished. I have got a rescue mission to go on later so that's it for today. Tomorrow should see the 240v system fitted and checked and the wardrobe fitted. Cheers - mike
Apr 27, 2022 12:21:05 GMT
hi all had a steady morning on the camper and have now fully installed and tested the 240v system. She's currently hooked up with the heater on, once i'm happy that its performing ok I will finish installing the trim. This afternoon should see the wardrobe being trial fitted. Cheers - mike
elfman
Its looking great, are you fitting a cooker or eating out ?
hi there
the wont be a hob fitted. I tend to use a portable one and cook outside or use a microwave.
Cheers - mike
I don't mean this sarcastically, (I'm saying that because I don't know what your every day employment is,) but that is a beautiful job that looks completely professional, The standard of your work is first class, Nigel
I don't mean this sarcastically, (I'm saying that because I don't know what your every day employment is,) but that is a beautiful job that looks completely professional, The standard of your work is first class, Nigel Hi there thanks for the compliment. I have been building campers for over thirty years on and off and enjoy the challenge. I worked as an operations planner for 30 years but retired at 50 due to poor health so now just potter about building and renovating campers and motorhomes. Cheers - mike
hopeso
Looks good. Hope you enjoy your trip.
elfman
Great job very impressed
dandam
Interesting to see how mpvs are being used as base vehicles now, rather that traditional vans.
Great work as usual
elfman
Dec 12, 2022 10:28:09 GMT
How did you get on using the van in the summer ? Whats it like to drive etc and would you make any mods from what we saw, I'm 6-2 so would you recommend a lifting roof...I am very impressed with the standard of finish. Hope it all went well.
spacekadett
F*cking take that Hans Brrix!!
Dec 12, 2022 13:42:04 GMT
I missed this until today, really is a top notch conversion. We’ve got a wheelchair adapted Sedona which, iirc is similar to the i800 other than being fwd. The cut out for the wheelchair conversion is big enough that the mrs can walk up and down the back of it ok, and I only have to duck a bit. I’ve often thought you could make a great camper or dayvan out of it
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Dec 13, 2022 21:24:48 GMT
hi there
the I800 are not really well suited to a camper conversion as they have a high rear floor due to being rear wheel drive. A Vivaro for instance has the same overall height but the floor is 6-8 inches lower. I have not converted a sedona but have driven a few and the are not a bad vehicle.
