Bits for these cars are so thin on the ground I'm after any offers of spares or reasonable ideas.
I'm short of two one steel wheels (5x114.5/4.5") I'll buy a whole set if I have to.
I'm short of an engine, so I need any block that isn't seized (4cyl 1500, 1700 or straight 6cyl 2.6) with a flywheel and clutch which will mate to the original column change
I now have a 2.6 straight 6, now missing the clutch/flywheel/exhaust manifold, will still pick up a complete engine/box if need be
Please drop me a message with pictures or any great ideas you have, need tat will travel.
"A Pierburg carb? It would be more economical to replace it with a funnel..."
I definitely have a 13” zephyr /zodiac steel wheel but only one . It’s pretty decent (on the terms it’s straight and it is not red rusty just a weird shade of blue )
If that’s of any use let me know ? 😊
Promising start - dropping you a message
Feb 14, 2022 17:38:24 GMT
Updated to reflect minor progress
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
Feb 14, 2022 19:34:06 GMT
Friend here in Essex has a 4 cylinder engine 1700cc type and a couple of standard steel wheels, he also knows a chap that may have a few spares also, would you like a contact number?
Feb 14, 2022 22:56:46 GMT
Yes please - drop us a message with it if okay? Cheers!
voodoo57
pm sent
voodoo57
Feb 20, 2022 15:35:56 GMT
Any joy? ?
oakesy
Feb 20, 2022 16:06:03 GMT
I've got loooaadss of Mk3 2.6 engine parts. Definitely have flywheels and clutch units. Which exhaust manifolds are you after? Tubes or hockey stick type?
'66 Scimitar Coupe Straight Six in no Paint '74 Scimitar GTE in Yellow '71 Jaguar XJ6 in Blue '76 Scimitar GTE '87 Scimitar Turbo Previous- '87 Scimitar SS1 Turbo, '75 Triumph Toledo, '86 VW Scirocco, '93 Scimitar Sabre, '85 Scimitar SS1, '76 Scimitar GTE, '71 Scimitar GTE
Feb 21, 2022 18:05:46 GMT
Voodoo- i've spoken to your mate and we're working on something (opposite ends of the country!)
Oakesy - messaged Cheers
