Fossilfish
Thank fossils for fuel!
Jan 24, 2022 17:09:37 GMT
Hi peeps, Seen this escort parked in a carpark nearby, I've noticed it over the years. I recently missed out on a E46 330i which was scraped as the owner didn't know I was interested in it. Last week I knocked on the door was told that the car was due to be disposed of, she was pleased I asked. The owner a older Japanese lady had it for the last 21 years. It's got 67k with all MOT's confirming it's accurate as it's got a 5 digit millage counter. Pictures as I bought it. It was last used pre COVID and not moved in a year and a half. It's fitted with 130bhp 1.8 but cranks but doesn't fire up, inertia switch is good so the relay and fuel pump is suspected. Issues -It's missing a toe cover on the bumper -Roof has a rip each side by the back window. -rear side cards fabric has come apart and needs glueing -Fuel issue/pump needs investigating The car reg ends in DW which states it was registered in Cardiff but has Dagenham plate surrounding and paperwork. According to HowManyLeft website indicates 60 or so 1.8 Convertible's taxed and not sure how many SI 130's. Not used to fords but this seems like a original car kinda wish it was a Mk5 as I prefer that shape but this bubble shape is of it's time. If anyone has genuine interior mats, toe bar cover for a Mk6 bubble bumper or a roof please PM me. What's your thoughts about them?
Last Edit: Jan 24, 2022 17:21:50 GMT by Fossilfish
1996 Jeep XJ Sport 2.5 Manual 1975 Scimitar 3.0 V6
Jan 24, 2022 19:37:21 GMT
I have never been a fan of the cabriolet but i really like this one and its good you saved it. If you would like the factory built sheet for it i can look it up . or if you need any part numbers . i have a 3 door si the same shape
Richard
Jan 24, 2022 19:38:34 GMT
I had a diesel convertible new as a company car, we loved it, no sports car but great fun for touring around Europe in.
Fossilfish
Jan 24, 2022 19:54:59 GMT
I have never been a fan of the cabriolet but i really like this one and its good you saved it. If you would like the factory built sheet for it i can look it up . or if you need any part numbers . i have a 3 door si the same shape Richard A build sheet would be amazing. What kind of systems/website do you use as I was going to speak to a local dealer/part centre. I do wish it was a hard 3 door hard top, I haven't driven it so hopefully it's relatively nippy. Appreciate it bud. I'll PM you shortly.
Jan 24, 2022 20:25:14 GMT
Pm sent
Fossilfish
Jan 24, 2022 20:55:41 GMT
Thanks to cpn105e with the build sheet. I was struggling to find the colour and was good to see all the details and spec.
Will go into the folder I'm putting together.
Amazing stuff
Fossilfish
Jan 26, 2022 11:43:12 GMT
Had a hour or so with the car this morning. Thanks to cpn105e found the paint code on the build sheet as Auralis blue 2, looks lovely on a escort cosworth Quick clean of the battery tray area and surroundings. Just some surface rust to edges but solid. Placed a decent fully tested and charged battery. Was lucky to find the original if not warped cover Once the negative was placed on the battery post the horn just keeps sounding....I tried the ignition with the red key, closing the doors with no joy. After my wife shouted from the windows I disconnected it. Popped the horn/hazard fuse (28) which allowed me to connect the negative try the car without my ears ringing. I think it's the alarm/immobilizer kicking in. Either way I can hear the fuse click for the fuel pump but no buzz. Will continue the fuel issue another time. Good news other than surface rust the sills are good and solid, the arches are original and again solid. Anyone know why the horn sounds continually?
Last Edit: Jan 26, 2022 11:58:52 GMT by Fossilfish
Jan 26, 2022 11:58:47 GMT
New battery in key fob
Fossilfish
Jan 26, 2022 12:00:47 GMT
New battery in key fob They are old style keys
Jan 26, 2022 12:37:59 GMT
Ah, fresh sand in the hour glass then !
Last Edit: Jan 26, 2022 12:38:45 GMT by westbay
Jan 26, 2022 12:45:37 GMT
Can't remember if it was that model or the one before (possibly both) that had a lot of fuse box issues when they were not very old. When you say you hear the fuel pump fuse click, you mean relay, right?
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '04 Seat Leon TDi 130 (Wet weather runabout) '03 Citroen Berlingo HDi (Parts hauler)
Fossilfish
Jan 26, 2022 12:55:48 GMT
Can't remember if it was that model or the one before (possibly both) that had a lot of fuse box issues when they were not very old. When you say you hear the fuel pump fuse click, you mean relay, right? Yeah the relay behind the main board. Strange as I had no horn sounds with the older drained battery which was jumped, removed charged then reconnected. The old battery was boated to the sides so was changed. Everything looks dry and clean around the board. I just can't hear a buzz for the fuel pump priming. Unfortunately the fuel pump is in tank and no access port. I'll drop the tank and test the wires prior to replacing the fuel pump. Thanks for any pointers and help
Last Edit: Jan 26, 2022 14:14:25 GMT by Fossilfish
Jan 26, 2022 12:57:30 GMT
If the alarm is sounding wouldn't that "cut" the ignition and the fuel pump ?
What's the grey 'thingy' just in front of the battery ?
Last Edit: Jan 26, 2022 13:15:43 GMT by westbay
Fossilfish
Jan 26, 2022 13:47:34 GMT
If the alarm is sounding wouldn't that "cut" the ignition and the fuel pump ? What's the grey 'thingy' just in front of the battery ? No idea but it has block fuses, labeled A,B,C,D,E,F. Think this car has PATS security system like other fords from this era, guess so many were nicked this system prevented joyriders and dumb owners like me
Last Edit: Jan 26, 2022 14:37:42 GMT by Fossilfish
Jan 26, 2022 13:52:14 GMT
There’s a relay if I remember correctly Behind the drivers side kick panel If it’s the same as the si we had a few years ago Changed this relay as this controlled the fuel pump and immobiliser
Last Edit: Jan 26, 2022 13:52:50 GMT by Mercdan68
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Fossilfish
Jan 26, 2022 14:04:03 GMT
That's the one I think I need to test, when I get time I'll test power to this or the relay itself. Otherwise test the fuel pump. I hear a click behind the fuse box. I believe it looks like this (Ignore the red arrow above it's a stock photo) but reading forum posts on a ford website, the fuel relay is listed as R7a. I believe a brown relay, circled below.
Last Edit: Jan 26, 2022 14:11:34 GMT by Fossilfish
Jan 26, 2022 14:58:22 GMT
Have you tried locking and unlocking the door with the key, I seem to remember thos was how to turn the alarm off.
Fossilfish
Jan 26, 2022 15:20:49 GMT
I did but I'll try once again.
Appreciate the replys and help.
Kindest regards Raz
Replace the horn with a bulb on two fly leads. Then you can avoid being shouted at, but still see if the issue is getting resolved.
The horn will sound unless the security system is disarmed, I'd be asking people that know how the system gets disarmed. It won't like having the battery disconnected, so it might be worth seeing if there a sync procedure for it after disconnect?
