Jonny69
It's always good, regardless of whether it actually works, to see some thermionic valves glowing away merrily. Thanks, I know what you mean. If I can’t cure the hum it would be really tempting to hide a little solid state amp inside. Pretty sneaky, but it would work!
Jonny69
May 16, 2022 12:28:53 GMT
I made a quick change to the heater centre point grounding resistors: I was actually trying out a bigger capacitor on the heater DC smoothing and I noticed the two grounding resistors were getting hot. Quick V = I x R showed I was putting 0.2W through 0.25W resistors which is a bit close (I know, I should have done this to start with). I upped the resistors from 100 Ohms to 150 Ohms and used 0.5W instead of 0.25W. Now they just get warm and I'm much happier with it. I decided the sound quality isn't that bad. This is what it looks like running in my lab: And with the lights off: Thinking about the residual hum; it's not the main heater circuit because I added another capacitor to the smoothing and it made no difference. It could be the heater on the rectifier valve which is on a different tap and still on AC. It's not that easy to squeeze in another bridge rectifier and capacitor, but I might temporarily connect the rectifier valve to the main circuit and see what happens. The next place to look is potentially adding more smoothing to the HT. I can do this with a bigger smoothing capacitor but I suspect it would probably prefer a choke inline. It's very low level 50hz hum though, so I suspect it's being picked up from unrectified AC somewhere.
May 16, 2022 15:25:34 GMT
I was going to suggest adding a choke somewhere, maybe even an external one, similar to those fitted to laptop power supply cables...
Jonny69
May 16, 2022 16:22:09 GMT
I got to the bottom of it. I added the rectifier heater onto the bridge rectifier and it made no difference. Then I bodged on a 100uF capacitor soldered at one end onto a convenient HT point and using a bolt hole: That seemed to make a huge difference, so I took out the 50uF cap and replaced it with that one:
Last Edit: May 16, 2022 16:24:49 GMT by Jonny69
May 16, 2022 20:47:57 GMT
Nice that such a simple solution was found.
Jonny69
May 17, 2022 10:48:10 GMT
Nice that such a simple solution was found. Yes, it could just use a bit more capacitance now... I think this is about the limit of what the rectifier valve can take though, before I start to kill it. The spec sheets state a maximum of 50uF which seems to be due to the inrush current when powering on (particularly when hot?) - effect being to shorten the valve's life. I don't think I'm too bothered by that given how much this is going to get used. I made the capacitor mounting bracket out of a Jubilee clip strap. It's secure enough that I could piggyback another capacitor on top to quieten it down further and it would still be secure enough.
Jonny69
May 18, 2022 13:59:02 GMT
I found the PDF about the circuit I've just built: www.bbceng.info/ti/eqpt/AM8_2.pdfI built the later version of the two. It doesn't go into quite as much detail as the Mullard book does about how it works, but it's much more conventional with a DC coupling capacitor in between the two audio stages. I'm still not sure why the negative feedback loop didn't work, but I suspect it might be the transformers I'm using. A better audio transformer without multiple taps would perform better anyway, but might also work better with the feedback loop. I guess there's also a small chance I've got the transformer output connections backwards (as they were a bit vague on the spec sheet). That would make positive feedback (I think) which would lead to that feedback screaming noise. I don't know.
Jonny69
May 23, 2022 11:59:27 GMT
Jonny69
May 23, 2022 12:02:06 GMT
The problem with most of these is the datasheets are out there but they're all in Russian. Example here for the IN-35 above. Literally no idea what any of it means!
May 23, 2022 21:08:50 GMT
I'm guessing the 220B/242B may refer to the voltage required to operate them. I have one Nixie tube (neon orange glowing type) that will operate at around 90V, similar to typical neon lamps such as found in mains appliances. Of course, you usually use a current-limiting resistor in series with them when running from mains voltages.
Jonny69
May 24, 2022 11:16:49 GMT
I'm guessing the 220B/242B may refer to the voltage required to operate them. I have one Nixie tube (neon orange glowing type) that will operate at around 90V, similar to typical neon lamps such as found in mains appliances. Of course, you usually use a current-limiting resistor in series with them when running from mains voltages. Good spot. Yes, B is Volts because they don't have a V in Russian Cyrillic. There's a reference to a 200k resistor above that. I'm not sure what the 0.25 B T means though, maybe coefficient of temperature / stability. Seems to maybe allude to adjust the resistor value to make a current draw of 0.5mA, which would be 100V with a 200k resistor. Whether it's AC or DC I don't know!
Jonny69
May 24, 2022 11:30:24 GMT
Jonny69
May 27, 2022 15:28:31 GMT
Just dumping a translation from the IN-35 datasheet:
D = 6-7mm
L = 18-20mm
Flexible conclusions
The IN-35 glow discharge indicator is intended for use in AC circuits with a voltage of 220 V, 50 Hz in household appliances and machines manufactured for the needs of the national economy.
Basic electrical parameters
Discharge initiation voltage, V, no more ... ...... 180
Operating current alternating, mA, not less ... ... 0.2, not more ... .... 0.5
Brightness, cd / m², not less ... ..... 80
Ready time (discharge delay time):
in the light, s, no more ... ......... 1
in the dark, s, no more ... .... 10
Operating instructions
Bending and soldering of the leads is carried out at a distance of at least 5 mm from the glass of the leg. When soldering, use a heat sink. Avoid repeated soldering and desoldering.
Recommended mode of application:
a resistor R = 200 kΩ ± 10% is connected in series to the indicator circuit: 0.25 W
It is allowed to operate indicators in alternating current circuits with a frequency of 50 Hz at a supply voltage above 242 V, while the value of the limiting resistor must be selected so that the effective current value does not exceed 0.5 mA.
Jonny69
May 30, 2022 10:31:46 GMT
Decided to waste some money on some IN-35 lamps. Literally got no use for these at all, but I'm intrigued by them. I got a mix of 50 red, yellow, white, purple and orange. Looks like some of them have the white luminophore coating inside, which dictates the colour, and the orange ones are uncoated. Pictures from eBay seller: I reckon one will go in the preamp, probably an orange one, as it really needs an indicator to show it's on. What I'm going to do with the other 49 is anyone's guess!
Last Edit: May 30, 2022 10:32:08 GMT by Jonny69
May 30, 2022 21:05:58 GMT
Do they operate at around 90V, like neon lamps do? I discovered I can run them from a small 12V step-up inverter, barely bigger than an Oxo-cube.
Jonny69
Do they operate at around 90V, like neon lamps do? I discovered I can run them from a small 12V step-up inverter, barely bigger than an Oxo-cube. I’m not sure yet. The data sheet seems to suggest they have a firing voltage of around 180V but need a resistor inline to limit the current. The issue I’ve got is the resistor value stated isn’t correct for the voltage and current stated in the specs. I’m going to use the variable PSU I modified and see what happens. I’ve also got a step-up inverter that does up to 180V DC and 250V AC with 12V DC input. Might have a play with that at lunchtime to see if it’ll be suitable.
Jonny69
This is my Chinese 12V-280V DC step-up: Connections: Green 12V input is labelled. The other green tabs are DC output. The blue tabs I think are supposed to be AC output, but the voltage isn't clear so I think it might be a square wave (I'll have to hook it up to the scope to see). The white plug, slightly out of view, needs to be tied together to switch it on. The jumpers labelled 1-4 select between 110V, 200V, 220V or 280V output. The output is not regulated and simply varies with the input voltage. It switches on around 7.5V and the highest I've taken it to is 18V input (e.g. powered by a Li-Ion drill battery). I originally got it to see if it would be more suitable for my battery-powered valve amp project than my home made one. Outputs are as follows: 200v range: 7.5V in 125V out 12V in 200V out 15V in 250V out 18V in 300V out 280v range: 7.5V in 175V out 12V in 280V out 15V in 350V out 18V in 425V out
Jonny69
Well it's not looking promising for the IN-35 lamps arriving. Showing as shipped on 30th May but the tracking is showing they're still somewhere in Ukraine. Probably have to claim this back from eBay on July 12th
Jonny69
Jul 23, 2022 11:50:49 GMT
Hey, these finally arrived! Quite looking forward to having a play at work on Monday. Must remember to get my variable high voltage PSU out the loft.
Jonny69
Jul 25, 2022 13:24:55 GMT
I've had a play on a breadboard and had these running with a few resistor values and voltages. Started with a 220k resistor and raised the voltage from zero up about 240V. Orange at 180V: Purple: Yellow: Red: White (?): They're all quite different brightness. They are indeed like little neon tubes but the current draw appears to be different between the colours so the trigger voltage is also different. The orange tube with no phosphor coating seems to trigger around the 80-90V mark whereas the coated tubes trigger nearer to 180V. Increasing the voltage makes them brighter to a point. Here's an orange tube at around 240V: I also tried with 100k and 50k resistors. They were noticeably brighter with the lower value resistors. However, it has highlighted that my variable high voltage PSU is little more than a high voltage source and cannot actually supply much current, even into these. That means it won't be any use as an HT supply for testing valves.
