Dez
Club RR Member Number: 34
It’s grim up north. Dez
@dez
Club Retro Rides Member 34
It’s no secret I’m a big fan on the older imperial systems, and I can see why they endured for thousands of years. If you’re a merchant or trader out in the field (or indeed, a layman attempting to barter with one of the aforementioned) and need to know if what you’re getting is a good deal with no measuring implements, then yards, feet and inches are a far superior system, even if it’s a good rule of thumb (see what I did there) rather than a finite measurement.
The French system was far sighted and well thought out, but too ethereal for the common man to be able to relate to at the time, which is why imperial systems still endured for so long.
Last Edit: Apr 1, 2023 21:19:32 GMT by Dez
And the Imperial system is so logical. I'm fortunate inasmuch as being the right age to be comfortable with both systems having started school at a time when we had both inches and centimetres on the rulers. The senior engineer at work often comes to me for assistance when he has to work with historic drawings dimensioned in Imperial units. My youngest can think in Imperial units if required but I'm fairly sure that puts him in a very small minority of his generation.
Frankenhealey
Club RR Member Number: 15
It’s grim up north. Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Thanks again for another lesson, but tbh I am quite glad that on the 835.729.554.78.932nd day god invented the metric system - or whoever it was, whenever. The French. They adopted it in 1795. I should have added ‘and took all of the fun out of measuring’. Last century I was involved in a job for some Americans and IIRC got some values in slugs, which is an imperial measure of inertia.
jimi
I tend to use whatever side of the measuring stick fits the best, not usual for me to write down a size with one side imperial and then other metric. However when it comes to thinking and visualising it's imperial all the way, that's because I grew up with it, metric wasn't taught/used at school.😎
dazcapri
North East
Enter your message here...
I worked on the roads 30ish years ago.I asked the clerk of works what the dip was (the measurement from the string line to the road surface no lasers back then) for the capping layer,he said 375mm I said what's the tolerance he replied inch either way.
Mk3 Capri LS
New Zealand has been metric for circa fifty years but many of us including some builders and sawmillers still refer to timber sizes in inches, even when the lengths we're buying/selling are measured in metres. It's just easier that way.
And the Imperial system is so logical. I'm fortunate inasmuch as being the right age to be comfortable with both systems having started school at a time when we had both inches and centimetres on the rulers. The senior engineer at work often comes to me for assistance when he has to work with historic drawings dimensioned in Imperial units. My youngest can think in Imperial units if required but I'm fairly sure that puts him in a very small minority of his generation. When I was going to school they were sort of teaching us both and, as a result I kind of know my way around both systems but, it still takes some thought.
You guys should try the oil industry one of the first rules as an engineer's assistant was "Always check the units" as different departments used metric or imperial. Even the metric Europeans used inches for drill pipe sizing.
The Metric Vs Standard ( as it is called here ) discussion is a funny one, and as I found out on one of my threads, some people get quite emotional about it.
Some inch sizes shouldn't have been messed with ( but they were).
For example a Morris Minor & a Mini have a 4 on 4" wheel bolt pattern.
English Fords have 4 on 4.25, Triumph 4 x 3.75, etc.
That's how they were built, they are easy to remember round numbers, why change it...
I do all my fab work on cars that were designed and built in Inch sizes by using those Inch sizes, and Metric for the metric ones.
It all seems to go much smoother that way...
Apparently even some very smart people can get this whole conversion thing wrong...
thomfr
If you want a real mess then buy a Volvo Duett:
Body (mostly): Standard and some Metric Engine standard untill 1968 then Metric Some add on parts (Electric etc.) Metric Rear axle US imperial.
So nice to work on you keep crawling under it and back to the toolbox ;-) Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
It’s grim up north. accord83
@accord83
Club Retro Rides Member 51
I know this is a digression of Dez’s thread, but my 74 Mk1 Escort has Imperial engine and Metric suspension, it’s part mk1, part mk2. Always has been.
It’s grim up north. stealthstylz
@stealthstylz
Club Retro Rides Member 174
The thing that makes me laugh is British engines with imperial fasteners but (round number) metric critical component sizes that are listed in crudely converted imperial.
Dez
@dez
The Metric Vs Standard ( as it is called here ) discussion is a funny one, and as I found out on one of my threads, some people get quite emotional about it. Some inch sizes shouldn't have been messed with ( but they were). For example a Morris Minor & a Mini have a 4 on 4" wheel bolt pattern. English Fords have 4 on 4.25, Triumph 4 x 3.75, etc. That's how they were built, they are easy to remember round numbers, why change it... I do all my fab work on cars that were designed and built in Inch sizes by using those Inch sizes, and Metric for the metric ones. It all seems to go much smoother that way... Apparently even some very smart people can get this whole conversion thing wrong... That is largely what I do. I work with mostly imperial designed and built vehicles/buildings/machinery these days, so that’s what I tend to use most. But if it’s matrix vehicle I will defer to that system, like with the lada. The funny thing is the UN system is actually more standardised than metric. You can have EITHER fine or coarse in any diameter or GTFO. Metric had an ISO pitch per diameter which is generally quite coarse for the diameter, then various fine or super fine threads that no one can quite decide on a standard for. Annoyingly the worst offenders for this are the ones used most on metric vehicles- m10, m12, and m14. M12x1.25, although very common on Japanese vehicles, is rarely used outside of the automotive world. Same with m10x1.25.
Dez
@dez
If you want a real mess then buy a Volvo Duett: Body (mostly): Standard and some Metric Engine standard untill 1968 then Metric Some add on parts (Electric etc.) Metric Rear axle US imperial. So nice to work on you keep crawling under it and back to the toolbox ;-) Thom I know this is a digression of Dez’s thread, but my 74 Mk1 Escort has Imperial engine and Metric suspension, it’s part mk1, part mk2. Always has been. Land Rover products are very bad for this also. I think it’s RRC and early 90s that have a metric engine bolted to an imperial gearbox in an imperial chassis with a metric body on it.
Dez
@dez
And the Imperial system is so logical. I'm fortunate inasmuch as being the right age to be comfortable with both systems having started school at a time when we had both inches and centimetres on the rulers. The senior engineer at work often comes to me for assistance when he has to work with historic drawings dimensioned in Imperial units. My youngest can think in Imperial units if required but I'm fairly sure that puts him in a very small minority of his generation. I’m not actually old enough to have been tought a single bit of imperial at school. Being a young whippersnapper at a mere 38 years old, we were thought we’d never need any of that old rubbish. Then I got into old cars, old bikes and old houses, and I quickly learnt that if you’re ever going to understand anything you’re working on, then yes you do really need to know it. it’s almost all I work in now. I find myself converting metric into imperial far more than I do the other way round!
Dez
@dez
The thing that makes me laugh is British engines with imperial fasteners but (round number) metric critical component sizes that are listed in crudely converted imperial. The British are the absolute worst though. I have a fairly strong hatred for BS threads and their stupid sizing system.
@stealthstylz
Just thought of another one that always makes me laugh - the Ford 1.8 TDCi Duratorq/Endura D which has all imperial fasteners in the block, and all metric in the head and everything else that bolts to the engine. Must be the latest to have that sort of silliness, think they stopped making them about 2012.
Dez
@dez
Also, a great way to bait the bald eagle riding, freedom loving, MAGA wearing, honky Tonkin’ good ol’ boys when they start on some racist diatribe about China and metric being the downfall of their great civilisation is to ask them about their spark plugs 😂
Even ol’ henry gave up on imperial plugs in 1928, and with the exception of a few oddball Chryslers every spark plug ever made since has been metric…
jimi
You guys should try the oil industry one of the first rules as an engineer's assistant was "Always check the units" as different departments used metric or imperial. Even the metric Europeans used inches for drill pipe sizing. Tell me about it, even worse is the "engineers" tape measure that is marked in tenths of a foot 😳 I've launched a few of them over the side in my time 🤣
The Metric Vs Standard ( as it is called here ) discussion is a funny one, and as I found out on one of my threads, some people get quite emotional about it. I was involved in that discussion I guess, maybe I've even started it by commenting on something like 5/16th of an inch. Now that another similar discussion occurs here I can only appologize to possibly have opened that can of worms again. Sorry Dez.
