Nov 29, 2021 21:50:19 GMT
what is a trickle charger? i have a 12v motorbike battery, and i also have a 12v power source in the garage. Can i some how trickle charge the battery from that ??
I am using this for 12v led lighting for if and when we have a power cut.
slater
Club RR Member Number: 78
12v battery chargingslater
@slater
Club Retro Rides Member 78
It's just a very low amp power supply.
You may well be able to use a LED supply or any small power adaptor really. That's basically all they are.
Nov 30, 2021 12:50:26 GMT
Your 12V supply will likely be <2A so very low power and won't sustain a trickle charger. Maybe worth looking at one of the solar battery conditioners? Mount it on the outside wall and run the cable inside.
Nov 30, 2021 20:27:32 GMT
12v power supply is a atx power supply. i think it does 5 amps.
as i say if it charges over 5 days that is ok, i just want it to stay topped up as i may never use it. its just for some lights incase of a power cut.
can i just put a live to it with a resistor in line? thanks
Nov 30, 2021 20:31:05 GMT
Funnily enough I had my SV on charge the other day after messing with the indicators and a tail tidy, on my rip-off optimate it was pushing 6A on pulse charge which dropped to 3.8A when it stabilised.
Nov 30, 2021 20:45:35 GMT
If you want to have it connected to the battery all the time, so that it's always at 100% charge, you need a floating charger (aka a battery maintainer). Something like this would do the trick.
Last Edit: Nov 30, 2021 20:46:06 GMT by daklone
Nov 30, 2021 20:48:53 GMT
oh i see, maybe id be better getting one of those lithium battery packs, they are also jump starters, come with charger etc ...
