Nov 22, 2021 15:46:21 GMT
Thinking out loud more than anything Does anyone know of a suitable replacement for the piece of #£&@ electronic pump with a mechanical throttle? Still at the 'what about' stage currently, might never happen TIA
Nov 22, 2021 20:55:05 GMT
You can fit the pump from the m21 diesel, but it is not an easy task and requires some rare parts.
Some people have experimented with the pumps from Merc 603 engines or 6BT cummins, but to be honest at that point you would be better just using one of those engines instead.
Thanks, I did wonder that Don't think it's going to happen anytime soon
what's wrong with your pump? not that much in them to go wrong.
Nov 23, 2021 10:45:20 GMT
It's a p38 range rover, seems to have forgotten it's coding, which apparently they're known for Just thinking about viable alternatives, but I'm not sure if it's worth it I don't like the car that much anyway
Nov 25, 2021 21:51:29 GMT
Take the m51 out and put an m57 in. Bolts right up to the box and if you get everything from the donor, it'll only cost you the immobilizer delete from the new ECU (may aswell get a few more ponies at the same time).
~184 standard, ~240 with a remap on standard equipment.
I had thought about that, but I'm not sure if I like the car enough to bother, and now my RRC is fixed I'm not sure if I can be bothered Anyone want a engineless manual p38??? 🤔
I had thought about that, but I'm not sure if I like the car enough to bother, and now my RRC is fixed I'm not sure if I can be bothered Anyone want a engineless manual p38??? 🤔 The m57 goes in the classic too I've put a td5 in my classic. It's a great vehicle now
Nov 27, 2021 11:34:27 GMT
I put a td5 in mine (twice!) Worst mistake I ever made Back with the 200 TDI I had fitted 10 years ago, has cost me about £2k to get back to a vehicle I can trust Hope you're more successful than me Xenocide, everyone I know who has had a td5 has had problems with it 🙁
