Sammo
Club RR Member Number: 103
Nov 19, 2021 11:16:48 GMT
You can get a rusty e39 530i for under a grand, would it be worth ot for the engine and box? or do you want to keep this all original? That may be the route I go down at some point, however it's not quite that simple. The main issue seems to be the exhaust manifold which due to the whacking great steering box needs to be custom made. That's what I've read anyway.
Follow Me On Instagram - @parttimecartinkerer
Nov 19, 2021 16:23:28 GMT
ahhh I see and i guess a rack swap is probably an escalation too far. Maybe a turbo manifold would help clear it
Sammo
Nov 24, 2021 16:51:26 GMT
I managed to get a couple of free hours over the weekend so popped out and did a couple of bits to make the OAP a little less, old! Firstly was the 12v socket. The original BMW socket and lighter worked absolutely fine but the old style socket wouldn’t hold onto phone chargers etc. I bought a twin USB socket from eBay a few weeks ago so it needed to be fitted. The panel that socket lives in was only held in with two 8mm bolts and then just lifted out. A couple of twists of the socket with some long nose pliers and it pulled out of the panel. Then I had to unclip the orange illumination ring and cut down some of the plastic so the new socket would fit. With the panel trimmed the new socket and securing ring fitted perfectly and could be refitted With that sorted it was time to move onto the next “modernisation”. The car has central locking but not remote central locking. As lazy as it sounds, having to put the key in the door to unlock the car was quite annoying and now that it’s dark so early I can’t actually see the door lock when I’m trying to lock/unlock the car! I picked up a universal remote central locking kit from eBay for about £15 and had a quick read up online about what I needed to wire it to in the car. It was really easy, only slowed down by me being anal with routing all the wiring along the original loom. If I could live with it being slapdash then I could’ve had it done in about 25 minutes. With the soldering, heat shrinking and taping it took me about an hour and a half. I forgot to stop and take pictures but it’s all working as it should and it just makes the car a slightly easier daily.
Dez
Club RR Member Number: 34
Nov 24, 2021 22:14:02 GMT
RE- poor acceleration/running/economy and stuttering. Try unplugging the MAF and see if it changes anything. If it doesn’t make it worse (it should do) give it a good clean, and if that don’t work replace.
Nov 24, 2021 22:30:53 GMT
I’ve got a LOT of spares for one of these if you need anything. Actually, a 70% complete spares car
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Nov 25, 2021 16:47:45 GMT
Nice car! With regards to your steering, mine feels super sloppy and vague too, keen to see the difference it makes to yours as mine is due some love over the next few months!
Insta: lewdeak1986 E28 518I 50% of a MK1 Golf 2003 Lupo GTI
Sammo
Dec 18, 2021 17:01:40 GMT
A brief update to the OAP, sadly with just one picture (it was getting dark!) I’ve been using the car as my daily but for the last few weeks it’s been feeling a bit underpowered, stuttering a little under load and generally feeling like it’s in the wrong gear all the time. I had to pop round to my garage to sort something else out so thought I’d give everything a quick glance over. I spotted that the overflow pipe going from the rad to the header tank is weeping slightly at both ends, mainly because the pipe is rock solid, so I’ll be replacing that. I checked all the HT leads were on properly and all the vacuum pipes were intact. Couldn’t see anything wrong with anything there. I then pulled the top off the air flow meter (this has been removed by someone before so just lifted off) and noticed the copper pickup was barely touching the track. I “adjusted” the pickup very slightly so it was touching the track with a little more force. While I was under the bonnet I wanted to adjust the kickdown cable to try and solve the issue with the gearbox seemingly always being in fourth! Just two 13mm nuts to undo and I wound the cable out one turn, then did the nuts up again. Now the main reason I had to pop to the garage was because on my way to work yesterday I went round a corner and heard something clonk under my seat. I carried on driving and a couple of minutes later noticed that my seat belt felt loose! I got to work and had a look and noticed the lower securing bolt had come undone from the seat and the belt was just flapping about!! Good job it happened when I was nearly at work and not while I was miles away from home and my tools! Anyway, I got that done back up today and put a block of locktite on the bolt to stop it happening again. With those small bits done I just took a drive to the nearest Tesco garage to fill up with Momentum. Wow, the car is completely different to drive. No stuttering, no lack of power and the car is now in the correct gear the majority of the time! Amazingly what five minutes adjusting things can do!
Sammo
Dec 24, 2021 10:50:06 GMT
Sammo
Dec 30, 2021 14:14:50 GMT
Today was insurance renewal day. A bit of messing around on the various comparison sites and I've got a years fully comp cover with agreed value for £125! For the first time ever I've paid the full policy amount in one go
Dec 30, 2021 17:00:00 GMT
Today was insurance renewal day. A bit of messing around on the various comparison sites and I've got a years fully comp cover with agreed value for £125! For the first time ever I've paid the full policy amount in one go If you don't mind me asking, who's that with ?? Nigel
Sammo
Dec 30, 2021 17:23:43 GMT
Today was insurance renewal day. A bit of messing around on the various comparison sites and I've got a years fully comp cover with agreed value for £125! For the first time ever I've paid the full policy amount in one go If you don't mind me asking, who's that with ?? Nigel Performance Direct. I’ve used them on and off over the years and always received good service from them.
If you don't mind me asking, who's that with ?? Nigel Performance Direct. I’ve used them on and off over the years and always received good service from them. Thank you, Nigel
Sammo
Jan 27, 2022 12:14:18 GMT
A brief update on the OAP. I’m currently at home dying of Covid (possibly a slight exaggeration!) but I’ve been cheered up a little by a parcel arriving from America It’s a pair of Moosehead Engineering Spherical Upper Control Arm Bearings. These are apparently the bearings to have and will improve steering feel, remove the typical 5 series brake shimmy and don’t really wear out! I’ll be fitting these instead of the Whiteline bushes that I bought last year. I’m just waiting on a load of bits from Autodoc and then I can get going on refreshing the steering, suspension and brakes all in one go.
Sammo
Mar 12, 2022 12:22:18 GMT
When I first bought the OAP I fitted my reasonably modern Alpine CD player with an Amazon Echo Auto. It’s done the job absolutely fine but it’s always bugged me that it’s not in keeping with the age of the car. A couple of years ago I bought an Alpine cassette player to fit into another car but never got around to it. To be honest I’d forgotten I even owned it! Anyway, I’ve fitted it into the OAP this morning and it looks much better I’ve got a cassette converter so I can still use my Echo Auto and have digital radio in the car as well!
Sammo
Mar 15, 2022 10:36:01 GMT
The car has decided to test my patience this week! I wanted to change the spark plugs as the NGK plugs that were fitted were the incorrect ones. I bought a set of the correct Bosch plugs and fitted them the other day. On the way home the car started misfiring occasionally and smelling rather fuelly! I nursed it along for a couple of days as it was still driveable and did a bit of googling and checked on the E28 Facebook groups. A few people suggested I fit a set of NGK plugs as they seem to work better in some of the 525e models despite being the incorrect plugs. So yesterday I fitted a set of the suggested NGK plugs and it's made no difference I've ordered a set of HT leads as I suspect it's one of those giving up but they're going to be a week or so to arrive! To add insult to injury I was meant to be taking the car to an exhaust fabricator on Thursday to have a new exhaust made which I've had to cancel and then just to make things worse the car decided to backfire this morning when it misfired and blew a hole in the already ropey sounding exhaust So it now runs like a sack of curse word and sounds like a bloody stock car!
Sammo
Mar 19, 2022 12:01:12 GMT
Yesterday I crawled the OAP to work while also deafening everyone Once there I chucked it on a ramp and this is what greeted me! That’ll explain it sounding rather loud!! Later in the day one of the body shop guys dragged his welder into the workshop and did his best to weld the rust back together! I then slathered it in Gun Gum to seal the bits he couldn’t weld and was left with this. Obviously it’s not a pretty repair but it’s completely sealed and sounds nice again. Strangely the misfire has now vanished as well!
zeberdee
Club RR Member Number: 2
Mar 20, 2022 18:52:42 GMT
Spotted this in the car park at Volksworld show today .
Looked spot on .
Sammo
Spotted this in the car park at Volksworld show today . Looked spot on . 👍 The first car I’ve ever had spotted haha!
Sammo
Mar 30, 2022 20:34:15 GMT
I finally got around to having my new tyres fitted today. The ones that the car came on had plenty of tread but were cheap budget tyres that weren’t exactly grippy! Plus they were the wrong size which meant the fronts would rub occasionally and the steering was ridiculously heavy. Anyway, the new Michelin tyres are much better and the correct size
Last Edit: May 30, 2022 15:54:30 GMT by Sammo
Sammo
May 30, 2022 15:53:32 GMT
The new HT leads finally turned up after a six week wait! I fitted them straight away and thankfully the misfire went. The car is still feeling sluggish but I can live with that for now! The MOT is due today and I know that the lower wishbone bushes are split enough to be a failure. So on Saturday I came into work and got the car up on a ramp. It took me all day due to seized nuts and balljoints that decided to just spin but I eventually replaced the lower wishbones with E31 8 Series arms (these have a spherical ball joint instead of a rubber bush) which are a recommended upgrade, and the track control arms with Moosehead Engineering UCAB bushes. While I was under there I also replaced the ARB drop links and one track rod that was well past its best! The difference in the feel of the steering is amazing. Plus the car actually goes where I steer it now. Fingers crossed for the MOT later today!
Last Edit: May 30, 2022 15:54:42 GMT by Sammo
