we have a lupo, n/s door window motor wont work. I have found out that the motor is ok, its the feeds to it, here is the plug
the two wires ive got I'm my hand are lives, one is at 7v and the other is at 12v?
anyway, i put a live to the blue/yellow wire, and the motor span when we pressed the window switch but when pressed up or down the motor only turned one way.
Is there a module that has done? To me it sound s like there is a H bridge somewhere that is not working , but i have no idea about this at all. I'm sure its common. the n/s window works fine.
thanks
thanks
