Hi,
Moved into the house last year and designed a garage from a company called shedbox. It took an age for it to be delivered due to covid (6 mths) and I self built it over 3 weekends with my step Dad.
I have a small garden and was limited on space. The garage stopped where it does as to not spoil the view from the kitchen diner area (it doesn't block) and the car port section meant you could still see through it when using the front door, which incidently is on the side of the house!
Now it is built I wish it was bigger!
The build:
OPPS forgot to put damp membrane between building and floor so jacked it up
Finished article (minus guttering and doors)
The view I was trying to protect and maintain with the car port
in use
Just enough room
The build:
in use
Just enough room
