oxb1l
Jul 26, 2021 16:44:14 GMT
my old mate had some wiring issues with his alternator on his petrol express , its a valeo alternator
he's basically taken all the wires away after a small fire.
we have tails in Heavy Red wire Thin black wire thin Orange wire Thin Grey/Red Heavy Brown with white lines
Any info much appreciated 🙏
Bill 07725000944
Need a bigger garage !
Jul 26, 2021 17:42:26 GMT
Heavy red will go the battery via the starter in most cases. Heavy brown/white will likely be earth, simple to check with a multimeter on continuity with a known earth point. The other 3 will consist of a 12v exciter from the ign+ to "start" the alternator, an output (usually labelled as W) for a tachometer/battery warning light and another output to an accessory such as field regulation or a split charge relay etc.
jimi
Jul 26, 2021 18:08:27 GMT
oxb1l
Jul 26, 2021 20:55:23 GMT
cheers guys I'll try printing these tomorrow and see how i get on.
does anyone have a picture of how it should look under the bonnet ?
my old pal is 88 and "started taking things off for something to do"
