I’ve always had a itch to scratch ever since owning my 1 st avenger back in the late 80s,and if I don’t do it now I never will So I’ve decided to sell a few of my toys to fund it It will be powered by the 760 turbo Volvo engine that we have developed in the s2000 that I bought without a engine on this very forum The s2000 has now been redistributed via eBay I will update with pics as I go I got it back in March
Started with stitch welding the shell Very satisfying job And cut out strengthening plates with the plasma cutter
Picked up a 4ha axle got a new old stock power lock diff and new bearings also new 427,1 cwp
Also had some fun fitting Clio 4 pots and 280ish mm discs as I want to run 15s I would possibly got 300mm disc under there but I can always play with that another day Arches and rear quarters in primer
The axle is a whole project on its own 😂 I’ve learnt a lot building the diff and cwp set up had to buy a few pullers and inch llb torque wrench but very satisfying When the cwp mesh nicely and preload is set Got some xr3i discs and to Calipers for the rear so more fabricating 👌
Sorry for big picture dump I will try and update it weekly
doing a cracking job there
Aug 13, 2021 10:48:38 GMT
Bought a door bar kit from demon tweeks , Nice and easy to assemble Put a few holes and used a dimple die in the gussets
Aug 13, 2021 10:50:23 GMT
Then had a play with a bead roller and some aluminium sheet for some interior cards
Aug 13, 2021 12:15:53 GMT
Nice work, Looking forward to seeing future updates on this thread, Nigel
