Hi all, I am considering using a 6 cylinder "white block" from a Volvo 960 for a conversion into a Ford RWD It would be preferential to use a manual gearbox but they appear unobtainable easily. As auto's are readily available I wonder what would be required electrically to use this option, if at all? I believe this box is the AW-40
I wonder if any knowledgeable folk on here could point me into the direction of some technical info or someone that's done this.
Many thanks.
Many thanks.
