totti
Guten Morgen! Found a very rare early 203 on ebay Kleinanzeigen.... Looks like it's never been welded/restored.... With OEM sunroof and roofrack.... Love that colour! The small rear screen of the early modells.....i love! Central speedo and 4 spoke steering wheel....only till 52.. 24oo0km....this can be real.... As a big bonus:The 1500cc BIG BLOCK from the later 403 is already fitted!From the factory it came with 1300cc /42 HP...this one has 58HP. So...today i will travel to the south and have a look.... Stay tuned.... Greet
Last Edit: Feb 10, 2022 22:02:36 GMT by totti
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
very nice I hope it is as good as the pictures suggest good luck and have a safe trip
Clement
ambitious but rubbish
May 29, 2021 10:22:38 GMT
Ooooh lovely that!! You seem to have gone from hotrodding 60's Ford with V6s to bumbling around in 50's metal. Either way I can't fault your choice!!
May 29, 2021 18:47:28 GMT
That´s really nice. Hard to believe it´s unrestored, it looks so good.
May 29, 2021 18:59:28 GMT
Take a trailer?
totti
Ooooh lovely that!! You seem to have gone from hotrodding 60's Ford with V6s to bumbling around in 50's metal. Either way I can't fault your choice!! No,i'm still in love with my blue ovals! :)But other makes have nice metal,too! So,last weekend roadtrip! Took the Fiesta for the 250km ...easy! To cut a long story short:I got it! But,the car needs some attention in many areas...but that was not a real suprise.The car got a restoration long ago...maybe more than 40 years ago.And it was a very good one! The car is from Switzerland and comes to germany about 15 years ago to the seller,a classic car collector.He drove it very little,mostly under 100km(!)per year. There are problems with the bearing from the waterpump and the shaft from the throttle is badly worn.Brakes needs some overhaul... Parked the Fiesta safely at the seller and headed back home with the 203! Had to stop about 5 times for checking the bearing from the pump... There are ignition problems,too.....and i think the last valve clearence check is 30 years ago.. Also,the fuel gauge doesn't show anything.... And the roof rack is VERY noisy! BUT: It get's me home! Next day:Checking the valve clearence! Easy! The spark plugs.... The air cleaner... After this the engine runs very smoth again! But it's a good one!Look at this! Seats ...like new!NO wear at all! Glove box....with the handle for the wiper!(If the electrical fails) Central speedo!I love! Registered it yesterday! Decal inside the RH glove box... More to follow! Greet
Looks fantastic ! well done !
Incredible
Congratulations.
That's a little pippin. Lovely.
Well done for taking an untried, 70-year-old car 250km home!
totti
That's a little pippin. Lovely. Well done for taking an untried, 70-year-old car 250km home! Yes,indeed it was something of a adventure.... I've done such trips more than once....and i got home always. Meanwhile i have looked for some more issues at the 203.There is a clonking noise from the underside when you lift the clutch pedal....looks like one engine rubber mounting is dead. So,the engine and gearbox has to come out..... The lenses from the semaphores are brittle/broken/melted(someone fitted a way to big bulb inside!).... No lenses available.... Also no hazard warning lights are fitted....that is a must for german Tüv!Don't know how it gets german paperwork in the past. I will fit this soon. And the rear lights have to be turning lights,too Lots to do.....like always! But it's worth! Greet
totti
Jun 18, 2021 14:21:26 GMT
Hi! Started work on the sedan... removed the oilpan....yes,good idea like always. 60 years of sludge....the engine is from 1960 and it looks like unopened till now.. The carb....pre cleaned... ...and after it was in the ultrasonic-bath... Opened the brakes and drained the oil on gearbox and back axle.... Ordered a long list of parts.... Greet
totti
Hi! I'm deep into it..... Engine & gearbox are out... The first damaged part:The universal joint from the propshaft is shot That was the clonking noise.... The next bad thing:Somebody filled in the WRONG gearlube into the rear axle:The bronze worm gear is massive attacked . The right oil is vegetable based SAE 90 GL2....but here was a GL5 oil in the axle. The bronze wheel took massive damage.So,i will look for a new one,but for now it has to stay.I will fill in a mineral oil SAE 90 GL1 with a MOS additiv. Carb is back from overhaul.... New hard chromed throttle shaft! Greet
Jun 24, 2021 12:53:53 GMT
These cars must be so thankful that you have stepped up to the job.
Knowledge is power,
And you have a power to make the difference.
Always good to see your updates, even if there is bad news in there too.
totti
Jun 24, 2021 20:56:28 GMT
These cars must be so thankful that you have stepped up to the job. Knowledge is power, And you have a power to make the difference. Always good to see your updates, even if there is bad news in there too. Thanks for the kind words..... I think this car has deserved a good job....and i love it! Greet
Had bookmarked before I even finished reading the first sentence!
So which one gets the hotrod treatment? I vote the commercial.
Supercharged and then air ride?
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
Jun 25, 2021 10:31:53 GMT
Bad news on the differential, ive heard about the modern oils doing damage but never seen myself, when you get it pulled apart perhaps we can have more pictures of the damage?
totti
Bad news on the differential, ive heard about the modern oils doing damage but never seen myself, when you get it pulled apart perhaps we can have more pictures of the damage? For sure you will see photo's of that mess.... But for now i will not pull the axle apart.First i have to look for another CROWN wheel....they are rare and expensive. And:It's different to a "normal" axle:There is still no noise! Greet
