I still have a copy of the magazine, if your interested I'll scan it and post up a link to it ?
Yeah that'd be dead cool
only if you've got a spare 5 minutes!
Is the engine from an X-19 the same family as the Uno turbo then? What sort of power does it run?
I always liked these. There was one in the garage of my friends rented house at uni. It was unbelievably rotten though.
The x1/9 had a 1300 or a 1500 Fiat sohc on carbs, with 75 or 85bhp. The first Uno turbo had a 1300 version of that engine with 105 and injection (the second version had a 1400 with a slightly different design.
Bizzarely, the 1300 in my Y10 is another design again!
Yeah they're the same base Fiat SOHC engine that was in lots of smaller Fiats from the 128 to the Mk1 Punto. As Duncan mentions they made a dizzying number of versions though. Closed deck/open deck, all sorts of different bore and stroke ratios that ended up making very similar (but not quite identical) displacements.
The early turbo ones were 105bhp at 0.7 bar, but they were intended to run at 1 bar (but insurance companies kicked up a fuss!). If you unplug the little boost sensor that cuts at 0.7 bar and add in a bleed valve to take it back up to the intended boost they'll happily put out 130hp and 145lb-ft.
This one's probably a little down on that, as we'll discover over the next few posts...
They all do that sir...........
They do...... I had a 1978 one in about 1988. It was catastrophically fall -apart rusty then.... and that was just the patches......
It didn’t have a turbo either, but it sorely needed be one. The 1300 ones are really slow.....
Nick
Yep! They do seem to rust pretty readily. Definitely one of the cars that built the Italian reputation for it. This one is in reasonable nick, but is still starting to go around the edges. Eventually it'll get a full teardown, de-rust and repaint but for now I've only got so many working cars so it'll have to soldier on for a bit longer!
And yeah, I can imagine they're pretty slow with the standard 1300 (and even the standard 1500 really). It's not just the outright power but the highish peak torque doesn't help them feel like they can scoot down the road. Something the turbo does help with immensely!
Very cool little car- remember seeing it for sale my way.
Thanks man
yeah the second I saw it I knew I had to have it! When it came up for the affordable price anyway...
Onto the next update!
Running problems resolved! - 16th August 2019So, during that whole time of rebuilding things I'd been chasing down intermittent running problems. One day it would run fine, and then the next it would run like absolute plop. This all started within the last 10 miles of the journey back from Wales. This was really rather frustrating as after all the work done to it over the course of the year it still felt like I hadn't really got anywhere. However, I do love a bit of a list and writing one out for the work done to date (rather than the work to do) did wonders for the motivation:
1. Removed dead nosecone and straightened panels underneath.
2. Fibreglassed on new nosecone and painted it.
3. Made new mounts for the front bumpers and number plate.
4. Knocked out the worst of the dents, did a spot of filling and painted them.
5. Bought alloy radiator from the States and made a tubular bracket to get it to fit.
6. Made stainless versions of the perforated coolant pipes.
7. Rewired the electrics for the starter and ecus.
8. Rewired the headlights so they have relays and don’t burn out the ignition stalk.
9. Replace burnt out ignition stalk from learning previous lesson.
10. Run an extra power cable from the battery to the fuse block.
11. Straighten front-left suspension links, and shrink the threads for the big top nut on the strut.
12. Replace both inner and outer tie rods on both sides.
13. Rebuild front and rear brakes.
14. Rebuild rear brakes again when they won’t bleed.
15. Rebuild rear brakes a third time with new hoses to get them to finally work.
16. Replace brake master when new brakes cause the old master to die.
17. Replace brake reservoir and hoses when pressure bleeder shoots a jet of brake fluid out of the reservoir .
18. Replace clutch slave when that blows a seal.
19. Replace clutch master when new clutch slave causes that to blow a seal.
20. Added a bronze bush to the gear linkage so it’ll select gears properly.
21. Modify an X1/9 sump and oil pickup to fit so it’s at the right angle for the car.
22. Replace coolant temp sensor and thermostat to see if it will make it run.
23. Try second hand AFM to see if it’ll run.
24. Replace fuel pump to see if it’ll run.
25. Change intake gaskets when I discovered I’d fitted one upside-down.
26. Modified a bung on the intake manifold to allow for easy removal.
27. Made a new set of HT leads, maybe that would make it run?
28. Tested fuel pressure and regulator. Both fine.
29. Checked for boost leaks. Nada.
30. Change rear coolant pipe that runs to the pump as it’s leaking.
31. Do timing belt and water pump.
32. Do valve clearances.
33. Modify coolant pipe as it doesn’t fit properly.
34. Modify coolant pipe again as it doesn’t seal properly.
35. Replace a second leaking coolant pipe.
36. Bleed the coolant system for the umpteenth time.
37. Finally replace the right sensor that was causing it to run like plop (rpm sensor on the flywheel).
38. Take it for MoT only for it to start running like plop again.
39. Spend another week chasing problems and rechecking sensor readings.
40. Miraculously starts running ok again (we reckon it was corroded connections to sensors that got cleaned when we were taking them on and off to test them).
42. New tyres (and slim spacers on the front because why not).
43. Troubleshoot some electrical problems with the headlights and dash illumination.
44. Refit a second hand idle control valve.
45. MoT and tracking.
46. Drive!
Scattered among that list is the stuff that I'd done to try and sort the running. Tested pretty much every sensor in the system, as well as replacing a fair few of them just to make sure (and because very little seemed to be improving things). The latest breakthrough at that point was discovering that the RPM sensor looked like this:
I replaced it with a new one which improved matters for a while but then seemed to have died again, prompting another replacement. By this point I'd finally started to notice a pattern. It tended to stop running nicely after bouts of heavy rain. Interesting...
Initially I suspected the RPM sensor again as I'd noticed there was some water ingress between the body of the sensor and the wire, but sealing that up on the new sensor didn't seem to help.
Then, about 17 months after it had first started running terribly...I cracked it!
I'd just fitted a second replacement water temp sensor as the first one I bought was reading funny resistances, but that made it run worse than ever. Then I remembered that it had chucked it down with rain the day before. Thought I'd check the plugs for water ingress. Made my way around the engine bay finding nothing, but when I got to the big plug on the fuelling ECU...full of water! Could have kept carp in it.
Little bit of searching around and I found this little drip coming out of the loom above the ECU.
What I think was happening was the drain holes in the engine cover were dumping water onto the mesh braid that covers bits of the wiring loom. That was then capillary action-ing all the way inside the loom, through the bulkhead grommet and spitting it out directly on the ECU plug!
I dried off the ECU and loom, wrapped up the braided sleeve in electrical tape so it wouldn't soak up water, rejigged the wires above the ECU so even if it did it wouldn't spit water onto the plug, and smothered the pins in dielectric grease.
After all of that, it ran! Halle-foxing-luya!
It still misfired off boost so there is something else going on, but great success! In a year and a half of driving after that it's never had those major intermittent issues again.
