Morris Lubricants 5 Litre Ankor Wax
I bought this years ago for a classic car project that I sold unfinished. So this is unopened but as seen is beaten & dented.
Protects against rust and corrosion.
Ankor Wax is a long term corrosion preventative, having low viscosity and surface tension, thereby enabling it to spread rapidly, penetrating into all inaccessible areas and covering all surfaces, however irregular.
It dries to leave a continuous firm wax protective coating that imparts excellent corrosion protection properties.
Ankor Wax has de-watering properties and therefore can be used where the metal parts to be treated are wet. All traces of water are displaced before the protective film is applied.
Ankor Wax is effective in damp and humid climates and gives excellent protection against salt spray.
