I've got some instructions for putting a strut back in to the wheel carrier for my car and it suggests using WD40. As I understand it a lot of people use WD40 as a lubricant, but that isn't what it is meant for. I've got spray grease available too, wondering if that would be a better choice.
Opinions please.
Always grease, preferably lithium based.
bstardchild
Club RR Member Number: 71
WD40 or Grease??bstardchild
@bstardchild
Club Retro Rides Member 71
Tend to use copaslip for that type of application - hopefully helps removal years down the line
Ooooh yeah I have a tub of copper grease too. Grand, will see if that makes getting this damn strut in to the right place easier. Thanks chaps
lrman
What car is it? You shouldn’t need any sort of grease or lubricant to fit or remove a strut attached to a hub with a pinch bolt assembly. You just need the right tool to open the hub up to allow the strut to fall in. You can make one from a large bolt ground down into a rectangle on the end. The narrow part needs to just fit in the gap and the the wider part opens the hub up when you rotate the bolt 90 degrees. Hopefully that makes sense
bstardchild
@bstardchild
What car is it? You shouldn’t need any sort of grease or lubricant to fit or remove a strut attached to a hub with a pinch bolt assembly. You just need the right tool to open the hub up to allow the strut to fall in. You can make one from a large bolt ground down into a rectangle on the end. The narrow part needs to just fit in the gap and the the wider part opens the hub up when you rotate the bolt 90 degrees. Hopefully that makes sense Until you try to get it apart 10 years later and find the hub and upright are rusted together..............
What car is it? You shouldn’t need any sort of grease or lubricant to fit or remove a strut attached to a hub with a pinch bolt assembly. You just need the right tool to open the hub up to allow the strut to fall in. You can make one from a large bolt ground down into a rectangle on the end. The narrow part needs to just fit in the gap and the the wider part opens the hub up when you rotate the bolt 90 degrees. Hopefully that makes sense You shouldn't need to beat off stuck alloy wheels with a length of 2x4, drill out snapped exhaust bolts or rounded off screw heads, helicoil stripped spark plug threads, or cut both sides of a bolt that's rusted to the inner sleeve of a bush, but none of those are unusual.
bstardchild
@bstardchild
What car is it? You shouldn’t need any sort of grease or lubricant to fit or remove a strut attached to a hub with a pinch bolt assembly. You just need the right tool to open the hub up to allow the strut to fall in. You can make one from a large bolt ground down into a rectangle on the end. The narrow part needs to just fit in the gap and the the wider part opens the hub up when you rotate the bolt 90 degrees. Hopefully that makes sense You shouldn't need to beat off stuck alloy wheels with a length of 2x4, drill out snapped exhaust bolts or rounded off screw heads, helicoil stripped spark plug threads, or cut both sides of a bolt that's rusted to the inner sleeve of a bush, but none of those are unusual. All of which could be alleviated with the application of a little non stick compound at the original (or subsequent fitment) But what the heck - life is for living
Feb 10, 2021 11:38:13 GMT
You shouldn't need to beat off stuck alloy wheels with a length of 2x4, drill out snapped exhaust bolts or rounded off screw heads, helicoil stripped spark plug threads, or cut both sides of a bolt that's rusted to the inner sleeve of a bush, but none of those are unusual. All of which could be alleviated with the application of a little non stick compound at the original (or subsequent fitment) But what the heck - life is for living Most could be alleviated; the curse word quality of the fasteners used on 70's BL and Fords were a separate problem. A tub of coppergrease should be on every mechanic's shelf. Drill a hole in the lid, and keep an acid brush in it for instant use.
bstardchild
@bstardchild
Feb 10, 2021 12:01:24 GMT
All of which could be alleviated with the application of a little non stick compound at the original (or subsequent fitment) But what the heck - life is for living Most could be alleviated; the curse word quality of the fasteners used on 70's BL and Fords were a separate problem. A tub of coppergrease should be on every mechanic's shelf. Drill a hole in the lid, and keep an acid brush in it for instant use. Exactly what I do - except I cut the brush down so it fits in the tin with the lid on
Feb 10, 2021 19:04:52 GMT
You shouldn't be using lubricant on any critical joint that relies on friction to hold it together, might make it easier to get it appart but it might move when it's not intended to.
On critical bolts best to use a threadlock which will also provide some protection against corrosion rather than a lubricant.
WD40 or Grease??fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
You’ve got to hand it to eBay’s content sensitive advertising in this post
lrman
Feb 13, 2021 15:56:26 GMT
You shouldn't be using lubricant on any critical joint that relies on friction to hold it together, might make it easier to get it appart but it might move when it's not intended to. On critical bolts best to use a threadlock which will also provide some protection against corrosion rather than a lubricant. Sometimes people don’t want to listen to that. Brake calliper retaining bolts that are single use that have been re used and fitted with a lashing of copper grease is something I usually see on cars that have been worked on by the local copper grease fanatics. My tool box has a draw full of the correct sprays, greases and locking fluids that are approved for use in different areas. I can get a photo of the tool I described above so you can make one. It does the job just right for removing and refitting struts with pinch bolts
