thomfr
Dec 11, 2020 20:52:55 GMT
In a dark corner of mu dad's garage attic I found a 4 wheel set for wheel alignment with rulers on them. (see picture for one of the 4, it was darp there and I have to bring it down later this week) I also know that he has somewhere a device which you can put on a wheel hub to check camber. ( of such a device is an example, not the actual one) What do I need more (beside a level floor) to do accurate wheel alignment? Doe anybody have a manual for these and is willing to scan it? Thanks, Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
Dec 11, 2020 22:48:43 GMT
I'd want something a lot more precise than that for setting camber. Having done a number of Vx Omega front suspension rebuilds, which need the camber to be carefully set I made this: Which is an aluminium disc turned to fit inside the wheel centre bore, held in with a magnet epoxied to the back face, and a sheet steel cover stuck to the front. Once in place on the wheel, it allows a basic magnetic digital angle gauge to directly read the camber to 0.1°: I zero the gauge on the slam panel. Omegas need the whole 4 wheel alignment done, but each time the cars have been put on a machine, the camber has been within a couple of minutes of what this gauge set it to. Cost was an offcut of ally and steel sheet, a neodymium magnet and a few minutes on the lathe. Plus the gauge, but I already had that for machining jobs. I did start making a similar tool with a laser to read both the camber and toe on a flag placed at the end of the sill, but never finished it
Is there a mirror somewhere in that wheel-alignment equipment? Maybe similar to the Dunlop gauge that I was given a while back, I did find a guide on how to use that (or a slightly different version of it) somewhere on line.
