Currently prepping for paint. There are lots of rust pits on the metal (all rust has been removed).
I have so far epoxy primed, flatted, filled the worst areas and given it a coat of high build (it's not very high build though!)
I'm going to flat this down again and 're prime but I can tell I'd have to repeat this many times before I'd loose all the pitting.
Its an old motorcycle so the parts are small and intricate so it's not as easy as just filling everything. I also don't really want to build up a high thickness of paint so I'm sanding back as much as possible before 're coating. Not really a suitable situation for a good heavy coat of polyester or similar.
I suddenly thought this may ve a good case for using some stopper, but I've not used it before. Does it still need priming over? I'm sure I've read you can top coat over stopper.
I did once have a tube of Halfords stopper I had used for something unrelated, it didn't seem very nice and never seemed to set very well.
Has anyone got any advice on stopper, or any other thoughts on dealing with the rust pitting?
If it was a car, this wouldn't be a problem. But I have about 50 small intricate parts to prep, all with varying degrees of heavy pitting.
Thanks.
Thanks.
