Could probably have some local repairs then be put on the road as a rolling restoration, but would certainly be better to give it a full resto.
There is plenty that needs doing, but I’ll list out a few items off the top of my head.
Both front outrigger corners have gone and I have cut them out, but the sale includes spare outriggers along with the body mount brackets and fittings.
Welding needed at the bottom of the A Pillars, rear arches, bottom of the spare wheel well, above the front grill bottom of both doors and I’m sure other places.
No carpet as it was horrible and going rotten.
Front and rear seats in brown aren’t too bad and will certainly be usable after a clean and a tidy
Gearbox cowling could do with replacement
Door cards and rear side cards look ok, but could also do with a clean and a tidy.
Rear brake shoes have been removed as they had jammed.
Accelerator pedal has been removed and a new mount will be required on the floor.
Comes with rarer 13 x 5.5” steel wheels already fitted.
It was running up until about a year ago and has been garaged since, if I get round to it I will try and get it started, but I can’t make any promises.
Also included in the sale:
- Temp sensor (unopened)
- Thermostat and gasket (unopened)
- Oil pressure sensor (unopened)
- Door to window seals (if I can find them)
- Door to window seal clips (unopened)
- Door to window seal clip fitting tool (Unused)
- Water pump and gasket (unused)
- Auxiliary drive belt (unopened)
- A random body mount (not sure which it is)
- Both front and second outrigger body mounts and fittings (Unused)
- New battery clamp
- Lockable fuel cap
- Bonnet / flip front
- Boot lid
- 2 x spare 13 x 5.5” steel wheels without tyres
£750 for the lot or I will consider splitting up the spares, just make me an offer if you’re interested.
Any questions, fire away and I’ll do my best to answer them. If you want to come and take a look, let me know, I’m working from home most days. It will obviously need to be trailered away.
- New battery clamp
- Lockable fuel cap
- Boot lid
