Paul
Oct 26, 2020 11:22:19 GMT
So here's where I'm at with changing out the driveshaft on this car... Tried to use the brake disc as leverage only succeeded in splitting the inner CV. I know there is a circlip on there but no amount of pry bar or screwdriver action will move it. The whole gearbox & engine are shifting but not the remains of this joint. What are my options? Try to remove the other side and drive it out through the middle?
Paul
Oct 26, 2020 12:20:19 GMT
Or, would it be easier to remove the differential access hatch (a bunch of 11mm bolts)...will I be able to see the circlip that's causing the grief from there?
Oct 26, 2020 13:19:09 GMT
I had one properly stuck years ago. I ended up drilling through the sides of the cup, putting a piece of bar through so I had something to hit then breying it out with a hammer.
ferny
Club RR Member Number: 13
Oct 26, 2020 16:32:41 GMT
Two pry bars and a friend sometimes get them shifted.
Oct 26, 2020 18:16:38 GMT
Try pushing it in, turning through 180 deg and giving it a good rattle. Then try pulling/levering again.
The aim is to try and get that nasty little spring ring to hang more favourably so it compresses into its groove and doesn’t just wedhe solid. May need a few goes.....
Nick
Oct 26, 2020 19:10:05 GMT
A drive shaft, driveshaft, driving shaft, tails haft (Australian English), propeller shaft (prop shaft), or Cardan shaft (after Girolamo Cardanol) is a mechanical part for communicating force and revolution best quality used cars in Kenya
Last Edit: Oct 26, 2020 19:13:02 GMT by juliekouba
Paul
Oct 26, 2020 19:20:25 GMT
Got there in the end...with the help of hairymel we dropped the pan on the bottom of the gearbox and wedged it out from within. Some good ideas here though, will remember for next time :-)
