Well after buying the car I turned up to pick it up and drive home for the owner to be outside with the bonnet up
He had the car for 2 years with no issue and the battery went flat so he changed it. then the whole car was dead
Turned out he caught a small spade terminal when removing the battery , so a quick refit and off she went
got her home fine with the only noticeable issue being a slight stutter at cruising speed , a worn drop link on the front and the auto seems to change gear a little early when on what
As soon as I got home I removed the reflectors off the doors and have given her a once over
So far in three days she has been cut , polished, waxed, fixed broken trim clips, ordered new rear spheres, new plugs, new leads. And a new GTi badge as the old one has been touched in.
