Are you putting a damp proof membrane between the steel and the timber? I think I would probably consider it. Morning mate No, not planning to. I can see no reason based on construction and use, to add more complexity to it. The timber fits between the steels, and roofing on top. Adding plastic to it would just add a water trapping barrier. I would expect everything under the roof sheets to stay dry and keep dry once built.
Last Edit: Oct 22, 2020 8:04:14 GMT by grizz
I agree that plastic would be worse than useless in that situation. Was thinking more along the lines of malthoid or a similar bituminous material if only to protect the steel from the effects of treatment salts leaching out of the timber over time. I'm an engineer's draughtsman and that's one of the standard things we specify for bridges with timber spiking pieces on steel main beams. Admittedly a bridge deck gets a lot wetter in service than the underside of a roof so you may well be old and grey before the potential corrosion becomes a serious issue.
Oct 22, 2020 12:33:26 GMT
I agree that plastic would be worse than useless in that situation. Was thinking more along the lines of malthoid or a similar bituminous material if only to protect the steel from the effects of treatment salts leaching out of the timber over time. I'm an engineer's draughtsman and that's one of the standard things we specify for bridges with timber spiking pieces on steel main beams. Admittedly a bridge deck gets a lot wetter in service than the underside of a roof so you may well be old and grey before the potential corrosion becomes a serious issue. He’s already old and grey so you’re saying it could happen anytime soon?
jpr1977
Club RR Member Number: 18
Oct 22, 2020 14:10:05 GMT
These with some adapters Grizz, you know it makes sense... stars
Last Edit: Oct 22, 2020 14:11:44 GMT by jpr1977
Oct 22, 2020 14:36:40 GMT
These with some adapters Grizz, you know it makes sense... starsWheels £200 Tyres £xxx Adapters £200-or more or less Refurbishment £50-200 Nope. Bit steeep at this point. But don’t stop throwing ideas here. Something will come along. Like 65mustang who has wheels in Holland.
Last Edit: Oct 23, 2020 7:53:14 GMT by grizz
Oct 22, 2020 18:50:42 GMT
I agree that plastic would be worse than useless in that situation. Was thinking more along the lines of malthoid or a similar bituminous material if only to protect the steel from the effects of treatment salts leaching out of the timber over time. I'm an engineer's draughtsman and that's one of the standard things we specify for bridges with timber spiking pieces on steel main beams. Admittedly a bridge deck gets a lot wetter in service than the underside of a roof so you may well be old and grey before the potential corrosion becomes a serious issue. He’s already old and grey so you’re saying it could happen anytime soon? Absolutely MRI this afternoon, I managed to scream in the tunnel too, when my back spasmed.
Oct 22, 2020 19:56:25 GMT
Today, before work..... And I also got this message from a member on here..... happy for him to expose himself. Hi Rian, Have you found yet if your winch is in working order ?? Only asking because I have a "girder trolley" (?? if that's what they're called lol) just wants a coat of paint, Yours for if it's any use to you, (in the spirit of Grizz,) FOC N***** So I went to the garage when I got back from the hospital after this: MRI of my lumbar and sacral spine which is a bit (lot) knackered. And cleaned and tested the 500kg block and tackle I had rescued at some point. Tested and found to be working perfectly well, untested on a load though. Cleaned up After cleaning and masking the block, I added a first coat of orange, next coat in the morning. And lastly......... Should, could these work on the rear end of the Rezin Rockit as a name? .
Last Edit: Oct 22, 2020 20:07:28 GMT by grizz
Oct 22, 2020 20:07:50 GMT
[quote author=" grizz" Should, could these work on the rear end of the Rezin Rockit as a name? . [/quote] I think they could work quite well, maybe in a slightly different format, replacing the X with a rocket sticker, just a thought
joeytalent
ITB Everything.
Oct 22, 2020 20:29:48 GMT
Today, before work..... Sorry you had to endure a Siemens MRI (I work for one of their rivals ). Good to see the car port come to fruition!
spacekadett
F*cking take that Hans Brrix!!
Oct 22, 2020 22:39:40 GMT
Had a thought wheel wise as my neighbour has an eagle chassis that has Land Rover wheels on the front. Figured it could be a cheap ish way to decent offset 16” steels or alloys but a quick look on eBay showed the adapters were about £135 a pair 😩
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Oct 23, 2020 14:25:01 GMT
Had a thought wheel wise as my neighbour has an eagle chassis that has Land Rover wheels on the front. Figured it could be a cheap ish way to decent offset 16” steels or alloys but a quick look on eBay showed the adapters were about £135 a pair 😩 Exactly. Some of the adapters go a lot more per corner. So I need to either find a set of used, cheap, unwanted 4x108 to something Japanese or popular, or just stick to what is available in 4x108 in the right offset.
Oct 23, 2020 20:08:45 GMT
Many coats later. Paint is quite translucent Happy with that.
Last Edit: Oct 23, 2020 20:53:37 GMT by grizz
Oct 23, 2020 20:33:02 GMT
Had a thought wheel wise as my neighbour has an eagle chassis that has Land Rover wheels on the front. Figured it could be a cheap ish way to decent offset 16” steels or alloys but a quick look on eBay showed the adapters were about £135 a pair 😩 Exactly. Some of the adapters go a lot more per corner. So I need to either find a set of used, cheap, unwanted 4x108 to something Japanese or popular, or just stick to what is available in 4x108 in the right offset. Or magically ship the steels from Holland
Oct 23, 2020 20:42:16 GMT
Exactly. Some of the adapters go a lot more per corner. So I need to either find a set of used, cheap, unwanted 4x108 to something Japanese or popular, or just stick to what is available in 4x108 in the right offset. Or magically ship the steels from Holland Mate........... If we could find a free ride for them from 65mustang in Werkendam in the Netherlands......... It would make the price worth having them for.
Oct 23, 2020 20:50:07 GMT
Got a message from Alpina99 Hi Rian, Have you found yet if your winch is in working order ?? Only asking because I have a "girder trolley" (?? if that's what they're called lol) just wants a coat of paint, Yours for if it's any use to you, FOC (in the spirit of Grizz,) NigelAdjustable. Perfect as the main beams are 135mm wide and the smaller ones 100mm So it has been established that the block and tackle works well. Gift accepted to be attached to the roof beams. Clean up and go.
craigrk headed over here........ Hopefully the timber beams will be up today, ready for when the roof sheeting gets delivered. .
Oct 24, 2020 16:04:23 GMT
Would need adapters obviously but would look awesome.
Oct 24, 2020 18:09:47 GMT
Would need adapters obviously but would look awesome. You joem83Are a bad Bad Bad Man. Those are pricey, but they are pretty awesome. They look really good.
mk2cossie
Club RR Member Number: 77
Oct 24, 2020 18:13:04 GMT
The front hubs could be swapped for Granada mk1 or 2 to give you 5x112 PCD, then its just some wobble nuts on the front, and adapters for the back and away you go
Oct 24, 2020 18:19:20 GMT
The front hubs could be swapped for Granada mk1 or 2 to give you 5x112 PCD, then its just some wobble nuts on the front, and adapters for the back and away you go Good thinking. I am not at all clever with this sort of thing. But that would save £100.00 plus £30.00 shipping from Latvia.
Last Edit: Oct 24, 2020 19:19:15 GMT by grizz
