I popped over to one of my neighbours who is building a retirement car. His little shed.... Edge drawn onto the plates. Tested on a bit of previously rolled scrap, the inverted J or walking stick was my first attempt. In order to get the feeling as I have never touched or used a bead roller. Starting out with the roller. First one done. Happy with that. Back home, just laid out. Bit of fine tuning before welding together. Next up, paint part of the rods with Hammerite, try leave it alone before threading the nets on, and then weld frame and plates together. And then paint the lot with Hammerite.
Last Edit: Oct 11, 2020 8:17:55 GMT by grizz
Oct 11, 2020 13:17:22 GMT
Oct 11, 2020 17:27:11 GMT
Thanks joem83I was happy with the result too. Those wheels appeal in a big way. If only one could get them fitted, simply.
Oct 11, 2020 17:47:34 GMT
Grizz, are you feeling OK? You seemed to of forgotten your safety flip flops.
Oct 11, 2020 17:55:41 GMT
Grizz, are you feeling OK? You seemed to of forgotten your safety flip flops. Good to see you back mate...... Surprised nobody commented earlier. Still predominantly in H&S flip flops but sometimes the weather makes me do silly stuff.
Oct 11, 2020 18:28:01 GMT
A few little things done today. One of them was just relaxing and wasting time. Also painted the metal bits from yesterday’s prep in black Hammerite Decided on black as it’s easier to patch up once I do the welding to get the bits together. joem83 posted these wheels up. £180.00 for a set of 4 in Bristol...... Not at all the right fit, unfortunately, as I do like the style again. And they are 15” afaik .
Last Edit: Oct 11, 2020 18:32:23 GMT by grizz
Oct 11, 2020 20:32:05 GMT
. 10 plus years parked outside in all weathers next to a shop in Scotland has to have its toll. Sadly, a 90’s built, U.K. Kitcar with 70’s and 80’s Ford parts and bits of wiring of suspect origin is bound to break your heart at some point. No matter how optimistic you may be feeling. Today I wanted to get started with removing the front screen in order to start creating the support for the fold down Land Rover screen. Sallys Uncle Bob the hoarder popped in for a couple of hours to check up on my progress and to see if I had space for one of his stationary engines or an Austin A35 he has been trying to get me to take, so my plans were a bit scuppered. But we rolled it down to the garage. Originally the car had a frame from the roll bar to the screen..... Radio-tape fitted. That thankfully fell off along the way from Scotland while Fil was recovering it But there is a mess of wires, including some bits I do not recognise, left over..... They need to be removed, but are fibreglassed into the frame. When I tried to remove the Land Rover mirrors though, they were not attached in an obvious way, so I found there was a channel up the side of the body with small rusty nuts, but not at all accessible...... So a bit of digging, pulling, pushing.... Wet plywood, rusty screws that would not screw out, but a couple of long screwdrivers later.... More rust down the bottom. Result. Still no progress on the frame or the mirrors. Either side. At least they are open. Next job will be to hire a 12 year old contortionist mechanic to reach up there under the dash, up he A-Pillar to undo those nuts. Then the wires to be unthreaded, maybe. Weekend over.
Oct 11, 2020 20:42:46 GMT
Banded mk2 transit, or banded mk5/6 transit would be my oddball 'Ave a look'. For wheel choice. I wouldn't be too worried about looms, it might even make sense to start again, even though that sometimes sounds like extra work. And some arch gap looks cool. auto-zine.com/gallery/5494/337734.jpg
Oct 11, 2020 21:03:56 GMT
If you have to get full on savage and end up cutting those mirrors off then I’ve a pair of spare arms here you’re welcome to.
Oct 11, 2020 21:11:31 GMT
Perhaps you would be better pulling the dash out and then have great access to all the area around the screen, it's going to have to come out to sort the wiring anyway.
Oct 11, 2020 21:18:34 GMT
Banded mk2 transit, or banded mk5/6 transit would be my oddball 'Ave a look'. For wheel choice. I wouldn't be too worried about looms, it might even make sense to start again, even though that sometimes sounds like extra work. And some arch gap looks cool. auto-zine.com/gallery/5494/337734.jpgThere are so many options, but I need to stay true to my original brief. And,as Paul Y and others have said, buying the right wheels is a sensible place to start. I still like the Rota look, and the wheels posted most recently, really appeal to me, despite probably not ever going to make it on.
Oct 11, 2020 21:19:32 GMT
If you have to get full on savage and end up cutting those mirrors off then I’ve a pair of spare arms here you’re welcome to. Thanks Glen, I prefer not to go that route if I ever can. Let’s hope I get them figured out.
Oct 11, 2020 21:38:25 GMT
Perhaps you would be better pulling the dash out and then have great access to all the area around the screen, it's going to have to come out to sort the wiring anyway. Kevin, you are right, as the existing dash, or instrument cluster certainly is way outside of my planning or vision. So pulling it will happen. The screws on the Cortina dash lip/eyebrow are mostly rusted away and it is half loose already. I want to retain that though as it works for me. But I should not pull too much apart till that fantasy carport is up. I did at least see the beams in real life on Friday.... they are looong.
Oct 12, 2020 11:44:02 GMT
Do you think the wires in the screen surround were fitted when it was layed up originally or glassed in afterwards? Maybe the "cover" on the wires would peel off? What about a couple of thin angle grinder discs to carefully open the channel they are in?
Oct 12, 2020 14:18:02 GMT
Do you think the wires in the screen surround were fitted when it was layed up originally or glassed in afterwards? Maybe the "cover" on the wires would peel off? What about a couple of thin angle grinder discs to carefully open the channel they are in? Yup. Fitted afterward for sure. Glooped in with loads of resin and glass. I do not want to cut it up while up there. So rather get it all undone under the dash and then cut the wires and aerial and wires on both sides. There are two lots of wires though, two fuses and that little box. It was fitted with a Moss alarm before. Bit worried that if I cut all the wires in one it could have an effect other places. But then a simplified, new loom could fix all of that.
Last Edit: Oct 12, 2020 16:49:06 GMT by grizz
Oct 12, 2020 16:46:20 GMT
If you plan replacing and/or relocating some or all of those gauges, and a revision of the electrical equipment, then I’d not be too bothered about cutting the obviously redundant bits out. The loom at the roof level is going to have been for the radio, speakers, an interior light and at most else something stupid like a CB or some-such other naff 90s accessory. Certainly nothing you’d want to reinstate. Chop it out and bin it.
Oct 12, 2020 19:29:19 GMT
If you plan replacing and/or relocating some or all of those gauges, and a revision of the electrical equipment, then I’d not be too bothered about cutting the obviously redundant bits out. The loom at the roof level is going to have been for the radio, speakers, an interior light and at most else something stupid like a CB or some-such other naff 90s accessory. Certainly nothing you’d want to reinstate. Chop it out and bin it. Thanks Glen, I agree, most gauges will fall away, and not be reused. I like the idea of setting it up as a “bare bones racer” with minimal functions monitored. And a new wiring loom if needed. There may be enough MX5 wiring etc there to use.
Oct 12, 2020 20:46:58 GMT
If you plan replacing and/or relocating some or all of those gauges, and a revision of the electrical equipment, then I’d not be too bothered about cutting the obviously redundant bits out. The loom at the roof level is going to have been for the radio, speakers, an interior light and at most else something stupid like a CB or some-such other naff 90s accessory. Certainly nothing you’d want to reinstate. Chop it out and bin it. Thanks Glen, I agree, most gauges will fall away, and not be reused. I like the idea of setting it up as a “bare bones racer” with minimal functions monitored. And a new wiring loom if needed. There may be enough MX5 wiring etc there to use. You only need a speedo and tach.
Oct 12, 2020 21:56:03 GMT
Fuel gauge could be helpful.
Paul Y
Oct 12, 2020 22:00:36 GMT
Fuel gauge could be helpful. Boost gauge would be better.... P.
