Sept 13, 2020 9:06:42 GMT
I reckon you’ve added enough value just by cleaning it, to break even on your costs so far if you decide to pull the plug. Looks so much better without the bull bar. Absolutely, Bull bar is,all good and well, but detracts from the classic front end. Interesting you saying that. craigrk and a few others on other forums have said that it has increased value, plus the fact that it is now in the South. Prefer not to pull the plug on this 🚀
Sept 13, 2020 9:10:18 GMT
You could keep the roll bar as a frame for basic weather hood /covers ... just thinking ... Morning mate. Roll bar is absolutely staying. It is a safety critical item imho. And part of the aesthetic of the car in my mind. I am looking for a thicker item, and slightly different design so that I can mount the anchors of the safety belts on it. Have been looking for truck items, but they maybe too thick. However, want a slightly thicker diameter pipe visually. Removing the one that is fitted is just to help with cleaning and as mentioned, will be to replace it with better. Like this-ish Also want it tilted back a bit.
Last Edit: Sept 13, 2020 9:25:34 GMT by grizz
eternaloptimist
Sept 13, 2020 9:15:41 GMT
Absolutely agree about it increasing in value. That’s looking superb. The front lights look like generic trailer or caravan type lights, I reckon you could clean up the backing plates and lenses easily enough, cut and polish a bit of alloy to make the reflectors a bit bigger and swap out the bulb holders easily enough. Keeping it basic will see it up and running quickly enough.
eternaloptimist
Sept 13, 2020 9:20:26 GMT
Alternatively, this
Sept 13, 2020 9:20:54 GMT
Absolutely agree about it increasing in value. That’s looking superb. The front lights look like generic trailer or caravan type lights, I reckon you could clean up the backing plates and lenses easily enough, cut and polish a bit of alloy to make the reflectors a bit bigger and swap out the bulb holders easily enough. Keeping it basic will see it up and running quickly enough. Thanks. Zoom into that light internals. It was full of water and the mounts are rusted away, completely. Cannot be trailer units, no red lens for stopping. So has to be something else. I think
Sept 13, 2020 9:22:18 GMT
Alternatively, this Interesting, I have seen one (the black £1500.00 on iirc) that had that done. Not to my taste. Square light suits square shape and straight line of it.
Sept 13, 2020 9:32:53 GMT
re the front side / indicator lights could you gut them get some cheap bulb holders from the e of bay and reuse the lens /case ?
Last Edit: Sept 13, 2020 9:33:46 GMT by westbay
Sept 13, 2020 9:37:19 GMT
Remove the whole light unit, and take it down to Aghabridge on Medway City estate. They're truck factors, so a browse of their stock and catalogues should provide a suitable modern replacement without any hassle. 7" round lamps are readily and cheaply available with the sidelights included, which could make the indicator choice easier
I would take the rears with me too.
Sept 13, 2020 9:47:40 GMT
If this is what you want to achieve (like some jeep shaped superseven kit car), you should really ignore all that talking of value. But it should make finding some fitting wheels much easier. Because now you can remove those stupidly wide arches, which to be filled would probably require some huge all terraim tires. So cut off and downsize the arches, get wheels you really like and then create arches around these, once the rockit is slammed as desired. All this talk of incresed value will only end up in a non-slammed stock dutton, but certainly not in the targeted grizz-in rockit. btw. those light units remind me of late renault 4 front indicators, but I doubt they are. And as the pic seems to show, the roll bar can be used for a bikini top to protect against rain AND shine. Thanks for removing that bull bar thing btw.
Paul Y
Sept 13, 2020 9:48:19 GMT
If you look at that picture the scope for getting this thing ABSOLUTELY on the deck is going to be a relatively easy task as the chassis is already Z notched. Might need a bit of creative repurposing, and possibly a few cups of tea whilst sucking through teeth, but that chassis definitely has... potential.... At worst you can potentially move the subframe up in the chassis and then work out sump clearance etc - there appears to be enough room to move stuff up and back. With access to your welder mates I would think that there is a relatively simple solution to gaining the altitude required. What the back like? Is the chassis Z'd notched as well or just straight. As for fitting supper wide wheels... easy as getting some Jeep flares and adding them to the existing fibreglass. This NEEDS super deep dish somethings. Steels maybe but more likely Watanabe or SSRs would look spot on with the look you are going for. Come closer so I can get my hand further into your wallet.... P. Or some revolution 4 spokes.. Yes....Yes....
Last Edit: Sept 13, 2020 9:52:49 GMT by Paul Y
melle
South West
It'll come out in the wash.
Sept 13, 2020 10:46:38 GMT
Off topic: can anyone ID the fusebox? Is it OEM or an aftermarket kit car item? I'm still on the lookout for a fusebox for my Saab 95 and it looks like this type could do the trick
Sept 13, 2020 10:47:11 GMT
That really has cleaned up well Rian, Amazing how a little, relatively cheap, bit of elbow grease can make such a difference, Looking forward to seeing the future updates on this project, Nigel
Sept 13, 2020 10:55:17 GMT
I think that’s an aftermarket fuse/relay box.
My comments about value were aimed at the point we’re at now, relative to last week, rather than next year. 😉
steveg
Sept 13, 2020 12:25:21 GMT
I think the indicators are the same as fitted to a Lotus Excel, a quick search says Lucas but not sure what they were fitted to originally.
Sept 13, 2020 13:16:45 GMT
Off topic: can anyone ID the fusebox? Is it OEM or an aftermarket kit car item? I'm still on the lookout for a fusebox for my Saab 95 and it looks like this type could do the trick Ford Escort ??
Sept 13, 2020 13:18:46 GMT
melle
South West
Sept 13, 2020 13:38:22 GMT
Last Edit: Sept 13, 2020 13:50:27 GMT by melle
Sept 13, 2020 13:43:32 GMT
re the front side / indicator lights could you gut them get some cheap bulb holders from the e of bay and reuse the lens /case ? Thought of implanting LED lamps in there too. Remove the whole light unit, and take it down to Aghabridge on Medway City estate. They're truck factors, so a browse of their stock and catalogues should provide a suitable modern replacement without any hassle. 7" round lamps are readily and cheaply available with the sidelights included, which could make the indicator choice easier I would take the rears with me too. I have been sorted on the rears Nick, thanks. Agh abridge is a great idea, they always deliver and actually want to do business. If this is what you want to achieve (like some jeep shaped superseven kit car), you should really ignore all that talking of value. But it should make finding some fitting wheels much easier. Because now you can remove those stupidly wide arches, which to be filled would probably require some huge all terraim tires. So cut off and downsize the arches, get wheels you really like and then create arches around these, once the rockit is slammed as desired. All this talk of incresed value will only end up in a non-slammed stock dutton, but certainly not in the targeted grizz-in rockit. btw. those light units remind me of late renault 4 front indicators, but I doubt they are. And as the pic seems to show, the roll bar can be used for a bikini top to protect against rain AND shine. Thanks for removing that bull bar thing btw. Bull bar was wrong in this case. I think the value everyone is talking of, is more just kerb appeal. If you look at that picture the scope for getting this thing ABSOLUTELY on the deck is going to be a relatively easy task as the chassis is already Z notched. Might need a bit of creative repurposing, and possibly a few cups of tea whilst sucking through teeth, but that chassis definitely has... potential.... At worst you can potentially move the subframe up in the chassis and then work out sump clearance etc - there appears to be enough room to move stuff up and back. With access to your welder mates I would think that there is a relatively simple solution to gaining the altitude required. What the back like? Is the chassis Z'd notched as well or just straight. As for fitting supper wide wheels... easy as getting some Jeep flares and adding them to the existing fibreglass. This NEEDS super deep dish somethings. Steels maybe but more likely Watanabe or SSRs would look spot on with the look you are going for. Come closer so I can get my hand further into your wallet.... P. Or some revolution 4 spokes.. Yes....Yes.... Will take rear wheel off, or crawl in there later for you. What 4 spokes? And yes, wide is good. That really has cleaned up well Rian, Amazing how a little, relatively cheap, bit of elbow grease can make such a difference, Looking forward to seeing the future updates on this project, Nigel Nigel, thanks for the reply. Yes, so many people cannot see past the moss and fungus. Cleaning up means I get to inspect it and get a feel for it already. At this point, looking at what is out there, and prices, I,a, still happy with it costing me about £780.-0 so far. I think that’s an aftermarket fuse/relay box. My comments about value were aimed at the point we’re at now, relative to last week, rather than next year. 😉 Indeed I think the indicators are the same as fitted to a Lotus Excel, a quick search says Lucas but not sure what they were fitted to originally. Steve, I would say a lot on this car came from a Cortina Crusader, vintage 80-ish.
Sept 13, 2020 13:53:56 GMT
Those are Britax indicator/sidelight units. linkAlternatively, how about a pair of these? link
Sept 13, 2020 13:58:00 GMT
Those are Britax indicator/sidelight units. linkAlternatively, how about a pair of these? linkSecond one is actually better looking than original Here are some more options. Team effort for sure
