mastra
Club RR Member Number: 131
Tilt sunroofmastra
@mastra
Club Retro Rides Member 131
Hi all, trying to find where to buy a tilt only sunroof from Car has one already but when I stripped it years to rebuild it I've lost the aluminium frame that sits between the roof skin and the rubber seal Where can I buy one from nowadays? Cheers all
93fxdl
Enter your message here...
Aug 22, 2020 15:13:15 GMT
Of you want a complete roof insert, early land rover discovery had two, tilt only with built in roller blinds Ttfn Glenn
Aug 22, 2020 17:53:54 GMT
Type 85 Audi coupe had a tilt or remove sunroof.
Aug 22, 2020 19:59:47 GMT
If it's an aftermarket one, I'm sure webasto make them
Hollandia 100 is a pop up
Hollandia 300 is an electric tilt and slide
Last Edit: Aug 22, 2020 20:02:15 GMT by joem83
mastra
Tilt sunroofmastra
@mastra
Thanks people, yeah its an aftermarket one fitted to a MK 1 Astra GTE just need a surround for it. I've plated it over a couple of years ago as I couldn't get a roof skin to do it properly at the time and with it having a full cage in it. Thing is though it gets bloody hot so considering putting the roof back in Will take a look cheers
