delux
There's treasure everywhere!
Dec 26, 2020 10:57:33 GMT
Yep that hole has been there a long time by the looks of things. No apparent cracks, rust or nasties so I’m not overly concerned. I’m having it taken care of in the new year once all this lockdown stuff has passed. mungo How much access is required to change a clutch cable and from which side of the tunnel?
ovimor
North East
...It'll be ME!
Dec 26, 2020 13:24:34 GMT
Loving all this beetle bug action..
"How much access is required to change a clutch cable and from which side of the tunnel?"
I recall replacing my Skoda Estelle acc cable with a Tandem Bike rear brake cable [cheaper + stronger] I tied a long length of the very strong, thin cord.. runs inside Cat5 data cable, to strip sheath.. Tied to end of factory cable, pulled out one way, then pulled bike cable back through.
OVIMOR
Last Edit: Dec 26, 2020 13:25:39 GMT by ovimor
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
delux
Not done much over the cold wet winter...but I have finally done a video edit for the wiring. Part 1 is here: Getting Wired pt.1
Last Edit: Apr 15, 2021 8:17:06 GMT by delux
Beetlejuice
Living rent free in heads since…
Apr 15, 2021 10:07:14 GMT
These look great! Sooooo much fun!
Stuck in the 90’s - mostly minis
delux
Last Edit: Jul 7, 2022 12:04:19 GMT by delux
delux
Jun 28, 2021 11:28:25 GMT
I was recently sent some images of the beach buggy by a previous owner - what a time warp they are! The buggy started off life on a different number plate and was originally orange with completely different wheels and 1200cc motor: It was then sprayed yellow and had white wheels fitted in the early-mid eighties, and at this stage had some purple paint applied but the owner changed his mind & went full yellow - I found remnants of purple while doing some body work. Interestingly the buggy also featured an engine cage which is no longer fitted - presumably removed when the new 1600 engine was fitted: It was then transformed again with nice shiny slot mags and a new registration number and had the canopy added too. It's fascinating uncovering the history of this buggy - which is sixty years old next year.
Last Edit: Jun 28, 2021 11:33:33 GMT by delux
1962 VW Beach Buggyjohnthesparky
@johnthesparky
Club Retro Rides Member 6
Jun 28, 2021 15:36:31 GMT
That’s cool That looks like a pancake motor from a type 4 in the earlier guise, but with an extra duct on it
delux
Man I’m bad at updating this… This buggy was a serious fire risk. The deeper I got into it the more flammable possibilities I found.. Here’s a video of me fixing the fuel pump. It used to fluctuate buzzing so I figured I’d sort it out. If it was wired anything like the rest of the buggy it was going to need some attention… If you fancy please follow on youtube
Last Edit: Jul 7, 2022 12:06:19 GMT by delux
delux
Jan 12, 2023 13:58:33 GMT
New seats for the buggy!
