Hello guys
It’s come to that time where I have to part ways with my much loved R33 skyline gtst spec 2 after many happy years of ownership. Below I will go over the spec and be as honest as I can about the car.
Before going any further this is not a drift car or an abused car this car is only used in good weather and has only covered around 8,000 miles in the last 6 years.
The engine
Rb25det
Metal head gasket
GTR pistons & rods
APR head bolts
ACL race bearings
Janspeed downpipe
Front mount intercooler
Full system exhaust
GTX2871r turbo ( new ) the car was running the standard turbo and I felt it would benefit from an upgrade. Still only running 12psi
Splitfire coilpack
340bhp with the current set up limited by injectors and ecu if these two were up rated this car would safely and easily make over 400bhp
Nismo 2 way diff ( no welded diffs here ! )
Interior
Very clean inside and all the toys work except the air con that was removed sometime ago to make way for the intercooler mods and engine mods
2 new bucket seats new on adjustable runners
Deep dish suede steering wheel
Gizmo ebc boost controller which displays boost etc.
Rear Rollcage - bolted in
Exterior
Outside bodywork is very straight
Paint is bright and clean but has obviously has work done in the past with some blemishes but for a car this old it’s a hell of a lot cleaner than most skylines on the road.
Fully under sealed 2016 and still in very good shape
Front bumper modified with spiltter and canards
Body has no damage the only let down on this car is the rear arches have started to bubble but easily saveable. If I was to sort the body I would ask a lot more for this car.
Alloys are new rota drift grids in bronze from Driftworks with loads of tread on the nearly new tyres
Front grooved brake disks
Suspension is only a year old was brand new from Driftworks HSD coil overs
Reason for selling the car is I barley use it as u will see when you check the mot history online and I need to carry out some home improvements ... adult stuff unfortunately lol
I’d love to keep the car but have to let it go if I was to keep it I would get the body work bits done and injectors and ecu to make use of them engine mods and you would have an awesome car it’s awesome as it is though lol
The engine
Rb25det
Metal head gasket
GTR pistons & rods
APR head bolts
ACL race bearings
Janspeed downpipe
Full system exhaust
Splitfire coilpack
Interior
Exterior
