Subject to a painstaking restoration to include
Blasting & repainting chassis & all associated components
Full body repaint in original Westminster grey
Rebuilt engine with new timing gear, tappets, real steel cam, skimmed & rebuilt heads
Wrapped tubular headers, stainless exhaust
All new
Lights
Fuel lines
Brake discs, pads, callipers
Transmission oil cooler
Rear quarter window rubbers
Plugs, leads, cap, rotor arm, coil
Re painted engine bay, bumpers
Re cored radiator
Rebuilt original steering box
Re veneered wood work
poly bushed
135000 miles
Jobs to finish
Install air con
Fix Weep from rear of sump
Bleed abs
Install headlining
Tune engine
Sort upper tailgate latches
Fit decals & rubbing strips
Refurb wheels & fit new tyres
cal Dan on 07966169803 for info
All new
Lights
Fuel lines
Re cored radiator
poly bushed
135000 miles
Jobs to finish
Install air con
Bleed abs
Install headlining
Tune engine
