Does anyone know where I can pick up a seat belt extender?
I bought a universal fitment one but the metal end on the fiesta is an arrow shape rather than a rectangle shape so it didn't work.
I literally need a small amount of wiggle room so I can pop a car seat in there!
Phil H
Club RR Member Number: 133
Seat belt extenderPhil H
@philhoward
Club Retro Rides Member 133
Jun 25, 2020 12:46:08 GMT
Bit of 3mm flat bar and a bolt to extend the stalk up a bit?
Only the same as the "mounting accessories" you get with a Securon seat belt kit.
Thanks Phil H
Not sure I have the tools or technical to fabricate anything though!
Last Edit: Jun 26, 2020 9:22:46 GMT by k11ngsley
Phil H
@philhoward
Jun 26, 2020 11:11:43 GMT
Hacksaw and a drill? Flat bar available at B&Q (or eBay for a lot less; 3mm x 30mm x 100mm should be sufficient).
Jun 26, 2020 21:24:34 GMT
Where in the country are you?
I will ask a friend.
Jun 29, 2020 18:36:25 GMT
Check the instructions for both the extender and the seat. I had the same issue with a P10 Primera years ago. Neither the seat maker nor the belt maker recommended their use.
Jaguar S-Type 3.0 SE
Thanks for the suggestions... Yes I really don’t think I should be making anything. I wouldn’t be confident on the safety aspect of it! grizz I am based in the south east, West Sussex
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Seat belt extenderduncanmartin
@duncanmartin
Club Retro Rides Member 70
I have a Securon 254 kit sitting around in my garage (I fitted 2 to the back of my 924, but it only fitted in the right side because of the shape of the reel). If any of this is useful, let me know...
Thanks for the suggestions... Yes I really don’t think I should be making anything. I wouldn’t be confident on the safety aspect of it! grizz I am based in the south east, West Sussex JohnnyBravo is around that area I think, otherwise I'm happy to drill holes in a bit of flat bar once you have it i'm in RH13
I have a home made seat belt extender in my Suzuki Vitara, a legacy from the previous owner, it is simply a piece of 4mm flat bar drilled, with rounded off corners bolted between the seat and the receiver, I 've not had any issues with the MOT man. It does make life easier in affording a little more freedom in the belt.
Jul 13, 2020 12:43:57 GMT
Thank you all for the suggestions duncanmartin I have no idea if these are compatible. Burton power also do some new seatbelts/rollers I can look at. I haven’t ventured to any shops yet because of lockdown. Barely been out the house since it all started but will look at the flat bar option when I can as this seems like the simplest solution.
Jul 13, 2020 13:28:03 GMT
Where can I actually get a 3mm flat bar from?
And will I be able to bend one end by hand to angle it so it comes out the seat alongside the car seat?
Jul 13, 2020 13:39:59 GMT
Where can I actually get a 3mm flat bar from? And will I be able to bend one end by hand to angle it so it comes out the seat alongside the car seat? B&Q, Wickes, etc. Hold it in a vice and you'll bend a long length by hand; shorter might need gripping with and adjustable spanner. As mentioned in an earlier post, the fittings that come with new seatbelts are bent from similar material
Jul 13, 2020 14:54:10 GMT
Seat belt extenderglenanderson
@glenanderson
Club Retro Rides Member 64
I’ve a couple of belt extenders in the store that came from my uncle’s place. I’ll try and find them. If they’re the right shape then you’re welcome to one.
