Roach
May 19, 2020 19:04:49 GMT
Tell me about the lowered spring plates. Do you use those instead of adjusting the torsion bar or as well as? You can fit them exactly as the originals are and that’ll give you a 2” drop. I’m going to fit these 1 outer spline up as well. See where she sits like that. The beauty of a drop plate is it gives the initial 2” drop without messing up shock travel and toe in etc.
May 19, 2020 22:21:48 GMT
Tell me about the lowered spring plates. Do you use those instead of adjusting the torsion bar or as well as? You can fit them exactly as the originals are and that’ll give you a 2” drop. I’m going to fit these 1 outer spline up as well. See where she sits like that. The beauty of a drop plate is it gives the initial 2” drop without messing up shock travel and toe in etc. Aren't they slightly longer too, to keep toe settings right? I seem to remember that if you really slam the back of a bug, the lower you get, the more toe in you get too as you run out of adjustment. Mind you, I stay largely stock height at the back on a bug, although my Ghia was five splines down when I got it...
Roach
Yeah I believe they’re slightly longer too.
shin2chin
Get it all fitted then man! I need to see how low this is going.
This is doing dangerous things for my want of another bug.
Looking forward to seeing how this comes out!
Roach
May 22, 2020 20:25:14 GMT
69 chinchilla grey beetle. Mercdan68
@forddan68
Club Retro Rides Member 68
May 22, 2020 21:29:19 GMT
That is spot on love it
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Roach
May 22, 2020 21:44:41 GMT
Thank you brother! Few days to get the rear wheels on, renew the steering damper, and fix the fuel tank leak... she’ll be all good. Small issues in the grand scheme of the turmoil she went through today. Poor old girl, unmolested for over 50 years, then I come along...
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
69 chinchilla grey beetle. retrolegends
@retrolegends
Club Retro Rides Member 94
May 23, 2020 14:39:59 GMT
Sweet 😎
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
May 23, 2020 18:24:57 GMT
Nice. I nearly bought a bug before I got my Imp.. I still have a hankering for one, maybe one day.. Good luck with it Cheers Col.
May 23, 2020 18:46:16 GMT
Thank you brother! Few days to get the rear wheels on, renew the steering damper, and fix the fuel tank leak... she’ll be all good. Small issues in the grand scheme of the turmoil she went through today. Poor old girl, unmolested for over 50 years, then I come along... Might be worth spacing the tank up by 20mm or so - a mate of mine wore through the bottom of his tank with the long track rod...
Roach
May 23, 2020 19:01:06 GMT
Thank you brother! Few days to get the rear wheels on, renew the steering damper, and fix the fuel tank leak... she’ll be all good. Small issues in the grand scheme of the turmoil she went through today. Poor old girl, unmolested for over 50 years, then I come along... Might be worth spacing the tank up by 20mm or so - a mate of mine wore through the bottom of his tank with the long track rod... Yes mate, that’s the plan with this when the tank goes back in. The fuel exit pipe was leaking like a sieve, so waiting on bits to fix that.
May 23, 2020 19:16:03 GMT
Have you considered an anti bump steer kit to flip the tie rods? Restores the angle to closer to stock, especially important on a lowered and narrowed beam. I had a set on my race bug, not hard to fit if you can get a 17mm drill bit.
Roach
May 23, 2020 19:33:54 GMT
Have you considered an anti bump steer kit to flip the tie rods? Restores the angle to closer to stock, especially important on a lowered and narrowed beam. I had a set on my race bug, not hard to fit if you can get a 17mm drill bit. Not something I’d even thought about Tbf. I’m not super low, so I’ll see how she drives. Never fitted them on any of my other slammed aircooleds. Worth a look tho. 👍🏼
Roach
May 27, 2020 17:08:21 GMT
Oofff that looks spot on.
Current: 1983 Volkswagen 1200 Mexico 2021 Kia Niro Hybrid ----- Former: 1989 Volkswagen Jetta 1990 Volkswagen Golf Madison 1996 Volkswagen Golf Wagon Happy Hour 2006 Fiat Panda 100HP 2006 Toyota Avensis Wagon
Roach
Finally get her home yesterday, but too busy cleaning other people’s cars to clean her! I raised the tank 30mm, as indeed the track rods fouled it.
shin2chin
That's looking ace. I've just ordered a pair of 6" steels for the rear of mine. Might have to copy your tyre size. What width wheels have you got up front?
Roach
Cheers man, 4.5’s up front.
