Change of plan forces sale -
2.5tdi engine. 150k From a Volvo 850 but same basic engine as a VW t4 ACV. Difference being bigger injectors, bigger 11mm pin fuel pump and bigget turbo. 140bhp as standard.
Comes with -
Cleaned and rebuilt head.
New cam seals.
New rocker gasket.
New timing belt, water pump and tensioners.
New fuel pump belt and tensioner.
New crank pulley (notorious for wearing)
New crank sensor.
Rebuilt oil pump.
2.4 sump (no oil level senser) and pickup
2.5tdi fuel filter bracket
Braided turbo oil feed pipe.
Volvo inlet manifold altered for Right hand intake.
Good condition ACV flywheel and clutch.
The fuel pump, injectors, turbo and manifolds are worth £250 easily.
Has been put in my caravelle but not used since rebuild.
Collection only due to weight.
Comes with -
New cam seals.
New rocker gasket.
New crank sensor.
Rebuilt oil pump.
![](http://img.retro-rides.org/i/v/dubwarrior2/169518c83317.jpg)
![](http://img.retro-rides.org/i/v/dubwarrior2/966688645713.jpg)
![](http://img.retro-rides.org/i/v/dubwarrior2/9a77c3e7010b.jpg)
![](http://img.retro-rides.org/i/v/dubwarrior2/a840df39c425.jpg)
