BMW E39 touring 523i
Year 2000
3000cc m54b30 engine
5 speed manual
MOT October
170,000 miles
Bmw e39 touring, was a 2.5 but i upgraded the engine to a m54b30 3-4 years ago when the car had 150,000 miles on it. The engine now has done 150,000 miles all in all. Gearbox is from a e46 328 that has done now 100,000 miles. Front brakes are 530i bigger discs and callipers. Has angel eye headlights, and after market smoked rear lights. Black cloth trim, needs a clean. Wheels are from a 7 series, there is a slight center bore mod which was done to get them to fit. Has detach tow bar that i have used 2 times.
Car drives ok, goes well, but the clutch has always been quite heavy, and since recently hurting my back and working in the middle of warrington has caused me a few problems. I think one of the rear brake callipers needs replacing as when you drive there is a squeaking noise. The air bag light came on recently. Needs a rocker cover gasket as most m54 type engines do! Will be due a service too.
The air suspension is good, no faults, fully working, recently had a genuine o/s sensor.
Car is in reasonable condition for its age, located in widnes nr liverpool
Year 2000
5 speed manual
MOT October
170,000 miles
£845
