I have a 24v vr6 eurovan that is a non-starter. Was ok but started stalling while driving like I had switched it off. No error codes on vcds (vagcom). Give it a min or 3 and it would start back up. Replaced the engine speed sensor, thought all was well and then it died again and would not start.
Vcds sometimes gives engine speed sensor value improbable value, but that is it. I'm starting to think that it's a broken wire in the loom.
Does anyone have a idea of the pins on the ecu harness end to check for continuity?
