Mar 28, 2020 18:38:52 GMT
I’ve just screwed the daily and tried all methods to get what looked like an injector seal out - turns out it wasn’t even there!!! it dropped into the valves at the top of the engine (I hope). - Audi TDI V6. Can the injector seat be re-cut in the cylinder head or would my copper seal make a good enough seal? (Not hopeful) This is the state of the cylinder head now
Mar 28, 2020 18:52:41 GMT
I did my injectors on a Saab and you have a cutter which aligns in the hole and then you cut off a light amount to ensure its flat for the copper seal to crush against. My mechanic told me that the gas forcing pass the seal will actually cause a small dent of depression so it needs cutting back to a flat surface . You also have the fun of trying not go get any swarf in the engine . A small bit of plastic pipe taped onto the hoover is good to get it out .
Mar 28, 2020 18:58:18 GMT
Course you can!
I’m getting daft and stressed lol, I’ve had the cutter down the hole today.
Thankyou, good to talk sometimes, even when you look daft lol
Mar 28, 2020 19:08:05 GMT
Yes , its all to easy to miss the obvious some time and you just need to bounce ideas of someone else . Its what this place is for !
Mar 28, 2020 19:32:52 GMT
make sure you use a thicker sealing washer.
