madmog
Club RR Member Number: 46
Mar 27, 2020 11:50:08 GMT
I've already made brake lines many times so am familiar with the general concept but now want to make up some hydraulic clutch lines.
Can anyone recommend a supplier of the wider (than brake) clutch line, unions and flexible hoses specified by end type and length please?
Also the flare making dies & presses?
Thanks
ChrisT
Club RR Member Number: 225
Mar 27, 2020 13:04:03 GMT
Mar 27, 2020 13:52:26 GMT
Speak to James at exact engineering in totenes Devon
Dez
Club RR Member Number: 34
Mar 27, 2020 14:08:32 GMT
You mean the actual hardlines?
It’s no different to brake pipe stuff. Indeed some cars have larger diameter brake lines. Pre war fords and Chevys are all 1/4” for example.
Brake stuff is 3/16”. It may get metricised to 4.76mm or even 5mm, but it isn’t. Clutch hardlines will proably be 1/4”. Or 6mm or 6.5mm depending on the seller. You will also see 5/16” (8mm) and 3/8” (9.5mm or 10mm) These are generally used for stuff like fuel lines and transmission cooler lines.
Thread sizes for fittings can be metric or imperial, you’ll have to use your best judgement given the vehicle to determine what. Be wary of stuff like Landrovers that can be either or both depending on the age of the vehicle though.
For the amount of fittings you will need to do one car it’s proably going to be easiest just to buy odd ones in the right thread sizes and a few metres of line off eBay at the moment.
Mar 27, 2020 16:44:46 GMT
bmw use 4.75mm line for the clutch.
got a chevy suburban waiting for a rear brake line outside, its 1/4 down the chassis to a flexi and 3/16 on the axle, which has metric fasteners 😆 its a 99 vehicle from memory.
madmog
Mar 27, 2020 20:40:03 GMT
Thanks all.
Yes actual hardlines. hadn't searched for them as "brake lines" Now I can find everything I need. Thanks all
