Mar 12, 2020 19:29:23 GMT
I do hope I know the answer,,,,,,,,,, BUT I want to be sure. Teeny, tiny bulbs that illuminate my car stereo. About 2mm across. Is it just the same as any of the other bulbs on the car, ie indicator/brake light bulbs. ?
For clarity I am talking about making sure they work, not the size...😄
Last Edit: Mar 12, 2020 22:40:39 GMT by waynedear
Bicycle x1 Alfa Giulietta (now wife's) Alfa 156 BMW 630i Honda rc36
Mar 12, 2020 21:22:48 GMT
I would think you have l.e.d's.
Mar 12, 2020 21:29:56 GMT
I would think you have l.e.d's. It is really hard to tell, they look like clear glass with a filament inside (unless that is what LED’s are like) Tried to get a picture. For scale with half a peanut...
Last Edit: Mar 12, 2020 21:32:56 GMT by waynedear
melle
South West
It'll come out in the wash.
Mar 12, 2020 22:27:28 GMT
That's a glass wedge T# incandescent bulb, you need to measure the diameter to figure out what the size is.
Last Edit: Mar 12, 2020 22:35:05 GMT by melle
Mar 12, 2020 22:39:28 GMT
That's a glass wedge T# incandescent bulb, you need to measure the diameter to figure out what the size is. I have 5 that I scavenged from my old stereo, I remember some do not work, I don’t want to put them in the new stereo (some bulbs in it don’t work) then have to dismantle it again to change bulbs again. I just wanted to know if because they are tiny I need to measure with the multimeter differently. 😁
melle
South West
Mar 12, 2020 22:44:50 GMT
Not sure what you need a multimeter for? Vernier calipers are more useful to measure the diameter.
TessierAshpool
Club RR Member Number: 168
Instrument bulb checkTessierAshpool
@tessierashpool
Club Retro Rides Member 168
Mar 13, 2020 12:52:16 GMT
That's a glass wedge T# incandescent bulb, you need to measure the diameter to figure out what the size is. I have 5 that I scavenged from my old stereo, I remember some do not work, I don’t want to put them in the new stereo (some bulbs in it don’t work) then have to dismantle it again to change bulbs again. I just wanted to know if because they are tiny I need to measure with the multimeter differently. 😁 Normal check with the multi-meter, either set it to "buzz"/"beep" and make sure it buzzes, or resistance and then check it's not infinite. Make sure you take them out of the circuit first though to avoid false readings.
Mar 13, 2020 22:37:39 GMT
I have 5 that I scavenged from my old stereo, I remember some do not work, I don’t want to put them in the new stereo (some bulbs in it don’t work) then have to dismantle it again to change bulbs again. I just wanted to know if because they are tiny I need to measure with the multimeter differently. 😁 Normal check with the multi-meter, either set it to "buzz"/"beep" and make sure it buzzes, or resistance and then check it's not infinite. Make sure you take them out of the circuit first though to avoid false readings. Brilliant, had them removed already, 4 out of 5 are good 👍
