Never used that one so cant give any advise for that product, I only use Tetraboost in my oldies and have done for well over 15yrs, It will boost the fuel up to the old 4/5 star rating depending on dosage and contains lead so no good for cat equipped cars
E10 Fuel Additives?ChasR
@chasr
Club Retro Rides Member 170
The issue will be 90s and 00s cars, where fuel pipes are formed.
At least on early 90s and earlier stuff, you can replace the hose. People will have to get inventive for the 00s cars I suspect.
OTOH, it's a great way to drive new car sales up, which are at a bit of a low, which even dealers buying up ex-lease cars just to keep the secondhand market priced higher.
Can't help thinking it is a storm in a teacup, ethanol has been used in other parts of the world for donkeys years, and there are plenty of older cars still going strong, the poor quality of hoses sold now etc worries me more.
Only thing I would be carefull of is long term storage.
my experience of cars from the 80's onwards, my 205 has about 600mm of rubber hose from tank to the steel lines, thd engine bay is plastic.
zx was the same,as is the bmw, touran is all plastic apart from the fuel filterz but thats diesel.
@chasr
Can't help thinking it is a storm in a teacup, ethanol has been used in other parts of the world for donkeys years, and there are plenty of older cars still going strong, the poor quality of hoses sold now etc worries me more. Only thing I would be carefull of is long term storage. To some degree, yes. On older stuff, well most, you can get decent hose from Cohline which will be resistant, and the hoses can be easily replaced ; the fuel tanks being metal will help matters too. But some older stuff will be questionable. Take my old Merc 280SE. That's got fuel injectors, a very early type of MAP sensor (it has brass belows inside) and a fuel pump which may not be able to be made ethanol resistant. That's a problem for keeping that on the road. Small wonder the Citroen DS folks rip off the D-Jetronic systems on DSs in France (yes, seriously ; it's something the Citroen Owners Club even recommends owners do ; that doesn't sound like a storm in a teacup approach ; some have caught fire with the D-Jet system with it basically always pumping fuel due to its design). Would Triumph PI stuff be OK I wonder or Mercs with Kugelfischer pumps; where a rebuild is £2.5k for one.... A document was present a while back on a Government website showing which cars would be 'safe' on E10 fuels; the rest of Europe went over earlier. Basically, it's anything after 2005ish. With stuff with formed fuel lines before than, which Pug 306s and BMW of sorts have, they'll potentially run into issues where an off the shelf solution can cause issues. E85 is known to eat into Ally to some degree, so again, that's another question mark around E10, although I reckon it should be OK at that level. Classic car fires weren't so well known about until E5 became more present at the pumps as well .
Last Edit: Mar 6, 2020 6:56:30 GMT by ChasR
dazee
Ethanol is water absorbent so will cause corrosion in steel tanks and fuel lines, I would definitely us an additive.
Dez
Club RR Member Number: 34
E10 Fuel Additives?Dez
@dez
Club Retro Rides Member 34
There has been ethanol in uk fuel since 1992.
A 5% increase isn’t going to cause the chaos the hand wringers are saying, unless you’re already running a car that isn’t ethanol safe on ethanol fuel.
Pretty much all European and American markets have been using ethanol in varying degrees (but all more than 10%) since the mid eighties. They didn’t make special non ethanol hoses for non ethanol markets in that time, they just made a ethanol safe hose for everything. My e28 bmw, ‘88 Nissan laurel, lada riva, ‘92 Passat all have ethanol safe fuel systems. A lot of American stuff goes much further back than that, ‘corn gas’ is all you can get in large parts of America.
The number of cars this effectS really is tiny, and they should have had ethanal safe stuff fitted 30 years ago anyway. no one has given a sh1t for the past 30 years it’s been in there, so why now with the marginal increase in %? It’s just the way our sensationist media works these days.
@chasr
Do you have proof of the US running more than 10% Ethanol? I was under the impression it was less. I know RoadKill have documented issues with US fuels which Freiburger dubbs 'Obamagas' so it's 'hardly an issue'. Maybe you can tell that to someone who had an engine fire and a car totalled .
Last Edit: Mar 6, 2020 19:10:08 GMT by ChasR
Dez
@dez
Google is full of information. All US pump fuel HAS to be a minimum 2% ethanol by law. The most common fuel in the US is E10 followed by E15. They’ve been putting ethanol in regular pump gas at up to 10% concentration since the oil crisis in 1974.
We as a market are way behind the times when it comes to ethanol. Most other markets have been using it for longer and in higher concentrations than we have.
A marginal increase from 5% to 10% content is inconsequential. Your car is either ethanol safe or it isn’t. And if it isn’t you shouldn’t have put fuel in bought in the uk since 1992. you can’t then act surprised when the fuel lines melt and it sets on fire.
Can't help thinking it is a storm in a teacup, ethanol has been used in other parts of the world for donkeys years, and there are plenty of older cars still going strong, the poor quality of hoses sold now etc worries me more. Only thing I would be carefull of is long term storage. To some degree, yes. On older stuff, well most, you can get decent hose from Cohline which will be resistant, and the hoses can be easily replaced ; the fuel tanks being metal will help matters too. But some older stuff will be questionable. Take my old Merc 280SE. That's got fuel injectors, a very early type of MAP sensor (it has brass belows inside) and a fuel pump which may not be able to be made ethanol resistant. That's a problem for keeping that on the road. Small wonder the Citroen DS folks rip off the D-Jetronic systems on DSs in France (yes, seriously ; it's something the Citroen Owners Club even recommends owners do ; that doesn't sound like a storm in a teacup approach ; some have caught fire with the D-Jet system with it basically always pumping fuel due to its design). Would Triumph PI stuff be OK I wonder or Mercs with Kugelfischer pumps; where a rebuild is £2.5k for one.... A document was present a while back on a Government website showing which cars would be 'safe' on E10 fuels; the rest of Europe went over earlier. Basically, it's anything after 2005ish. With stuff with formed fuel lines before than, which Pug 306s and BMW of sorts have, they'll potentially run into issues where an off the shelf solution can cause issues. E85 is known to eat into Ally to some degree, so again, that's another question mark around E10, although I reckon it should be OK at that level. Classic car fires weren't so well known about until E5 became more present at the pumps as well . Most of these fuel systems are 40 odd years old I can't help wondering how much is down to ethanol and how much simply to age, at this age any rubber parts will be well past their sell by date and additives should take care of corrosion and tribological issues. I'll be changing the hoses on my efi range rover but I was going to do this just based on age anyway.
@chasr
Make no mistake, it's worth changing the fuel hoses for half decent hose.
On my 2CV and the 280SE (albeit the latter started leaking in the engine bay) I changed the fuel hoses for this very reason. After all, it would be a shame to lose a car due to simple issues.
Drove the length of France for the first time 3 years ago (and each year since) and noticed that a lot of the E10 pumps had a notice on them saying anything built since 2000 was fine with E10 ... Seems odd that a 2003 Golf for the French market would have a different fuel system from one for the UK market...
Wouldn't you know it?
Most manufacturers will quote a date from when they tested ethanol fuels, they are not saying cars before that aren't compatible just that they have no idea what if any the effect will be and certainly aren't guaranteeing anything.
madmog
Club RR Member Number: 46
E10 Fuel Additives?madmog
@madmog
Club Retro Rides Member 46
In case it's of use to anyone, I recently bought SU carbs & parts from Burlen and upon hearing (probably the same) reports that E10 was coming I e-mailed them and asked if any of the internal parts would need changing. They confirm that their carbs and hoses won't be affected.
If anyone's rebuilding original ones it might be worth checking if anything needs updating while it's apart.
