Feb 28, 2020 13:44:58 GMT
I'm after a new st of wheels for my imp, and ive seen a set in the size i want 6x12 . The stud pattern etc is correct, tyres i can sort but what is doing my head in is the offset, its listed as +4 and ive tried so hard to work it out that I'm now confused. will they fit? or wont they? or will i need spacers? HELP!! TIA
zeberdee
Club RR Member Number: 2
Feb 28, 2020 13:48:45 GMT
milk
Feb 28, 2020 16:20:25 GMT
I clicked on this to recommend the website that zeberdee mentioned. it has helped me numerous times as wheel stuff goes over my head.
Feb 29, 2020 17:23:58 GMT
Google " Hillman Imp Wheeel Measurement " there is some useful info there. Looks Like 6" rims would not be suitable. Remember the tyres are wider than the wheel.
Wheels- offsets and brain acheballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Feb 29, 2020 20:51:18 GMT
Super lazy way to check if they fit is just to Google the new wheel specs with the make and model of the car. Most of the time you'll see results of people on owners groups showing that your new wheel spec does or does not fit.
at is the offset of your current wheels?
slater
Club RR Member Number: 78
Get your tape measure out. All the +4 means is the centre line of the wheel sits 4mm "inset' from the face of the hub. If you convert the 6inch into metric. (Approx 150mm) it would mean the wheel comes out about 70mm from the hub face..
We where very nearly caught out what ever you do just measure then before you pay, we have 12 Landrover wheels only 6 fit, several have the same part number but different off sets
It will come in handy even if you never use it
According to this website: "Imp tuning & modification by J.D. Hansen: Wheel width is restricted to 5½" at the front and 7" at the rear by the space available. And there is no point in exceeding 5½" all round on a road car."
Wheels- offsets and brain achefr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
According to this website: "Imp tuning & modification by J.D. Hansen: Wheel width is restricted to 5½" at the front and 7" at the rear by the space available. And there is no point in exceeding 5½" all round on a road car." This picture tells me there's every reason to exceed 5.5" ... ... albeit this is fitted with wide arches so more space is available. These are 8" wide but there's always the balance consideration of extra width / wheel weight has on performance vs additional grip meaning faster through corners. www.fastcar.co.uk/cars/modified-hillman-imp-on-air/
According to this website: "Imp tuning & modification by J.D. Hansen: Wheel width is restricted to 5½" at the front and 7" at the rear by the space available. And there is no point in exceeding 5½" all round on a road car." i ran an imp coupe with 6" front and 6 1/2" rears and no problems , but back then i had the luxury of being able to try the wheels before purchase
Sounds like you need an Imp expert. Have you tried any of the model-specific forums?
Mar 10, 2020 19:58:42 GMT
iam building a husky at the moment ive tried to find some info out on suspension set ups on here but got no reply's ive trail fitted some mini starmags 7x13 175 50 13 tyres with no springs on the car and they clear fine with suspension right up and turn
