My van will be available from 2nd March.
Super reliable 1.7 straight diesel, i'd drive it anywhere.
Recent Starter motor, alternator and battery.
Only selling as I've got to many projects, so its just sitting doing nothing.
Small thread here from when I got it,
forum.retro-rides.org/thread/209526/1997-vauxhall-combo-van-isuzu
Only known faults -
Gear linkage is a bit sloppy but selects gears fine but vibrates in neutral at lights etc.
Stone chip on n/s headlight, passed mot fine and dirt cheap on ebay if you wanted to replace it.
also when I used it the other week - the main beam flashed on the dash a couple of times as I used the indicator stalk, only since its been sat so guessing moisture or connection on the stalk needs a clean, will probably sort itself out with use?
Its available from the 2nd March, Mot until November if memory serves me right.
A genuine reliable hack, great for picking up engines and does an easy 50mpg.
Usual scabs of rust but cleans up well for a 23yr old van, no offers -£500 to a retrorides member - would rather it sell cheap on here than stick it on ebay.
PM me if interested and wish to view.
