Feb 14, 2020 15:07:38 GMT
Afternoon all
I need to order some cable to extend from my autometer tacho to the back of my beetle.
I have had a look at various diagrams but it doesn't tell me what size the wires are. Is there an easy way to measure these or does someone have an idea as to how thick they are?
Cheers
1967 Beetle
Feb 17, 2020 18:14:34 GMT
Incase anyone was wondering I found out through autometer they use 16 or 18 gauge wire on the sport comp tacho I'm using.
Am I right in thinking 16 gauge is about 1.2mm and 18 is 1mm
1967 Beetle
Phil H
Club RR Member Number: 133
Autometer tacho wiring sizePhil H
@philhoward
Club Retro Rides Member 133
Yep, that’s about right.
Surprised it needs wire that thick to be honest. 1mm should be overkill for a tacho.
slater
Club RR Member Number: 78
Autometer tacho wiring sizeslater
@slater
Club Retro Rides Member 78
Do you know the current draw? That's what you can calculate the wiring requirement from.
Phil H
@philhoward
I’d expect it to be well under an Amp - unless it’s got an inbuilt 21W shift light!
Feb 19, 2020 12:45:08 GMT
Do you know the current draw? That's what you can calculate the wiring requirement from. They suggest using a 4 amp fuse on the live and a 1 amp fuse on the shift light.
1967 Beetle
slater
@slater
Feb 20, 2020 12:45:41 GMT
Ok, 0.5mm or 20awg is good for 11amp. That's probably what I'd go for.
Phil H
@philhoward
Feb 20, 2020 22:02:04 GMT
I always reckoned 1mm per 10A as a ballpark. Not stunningly accurate but safe up to about 40A or so.
Last Edit: Feb 20, 2020 22:02:34 GMT by Phil H
