Since getting my MR2 project on the road and the Norway trip i have been a bit quiet.
Its not that i havent been doing anything but i do seem to have missed out on updating you all.
You may have seen i have been playing with the lathe and that has taken a fair bit of time.
I finally got some finishing touches done on the workshop.
Only taken 3 years but i finally got the doors insulated and the vapour barrier up
Followed by 9mm mdf and white emulsion
This also meant that i could finally finish the wiring for the lights.
With that done i spent a few weeks tidying up my storage areas since it was getting a bit overrun.
On the smaller jobs side its mostly just been playing on the lathe,
I needed a dimple die of a particular size so made it.
Found someone on ebay selling a load of bar ends for cheap so grabbed a bunch. And threw a quick storage solution together.
Needed a new handle for the lathe tailstock.
I bought a few drafting sets
Mega cheap and just needed a bit of a tidy up.
A set i gave my dad was missing a lead holder so i turned out a quick one
I wanted to make a slightly bigger tap handle since i have the odd tap that doesnt fit my usual one.
I'm copying the presto handle i already have which is pretty much a lathe only project. Which is convenient since i don't have a mill. Hole marked up and then drilled on the pillar drill.
The flats were done on the bench grinder and then finished with the file.
I realised later that i probably could have used the surface plate and made the hole and flats on the lathe. Maybe a challenge for another time.
Oh and i made a new scribe, nice bit of fun.
Then for a bit of something different there is a project i have been trying to get around to for years.
I could do with a shrinking stump.
An oak sleeper stacked in the back of my dad's workshop seemed like a good candidate.
Cut into 3 lengths, planed and thicknessed
I aimed for 30” which seemed a good hammering height for me.
Drilled out for some m20 threaded rod since i had some laying about.
Then a bit of 2” 10mm flat bar cut and folded to make a strap for the top.
Glued the 3 pieces together and bolted it all up.
The base was a bit overkill being 50x100x8mm angle but its not going anywhere.
Carved a bowl into the top and applied a bit of linseed oil.
Then it would be rude not to test it.
Followed by a bit of dolly and slapper work we have a workable panel.
Its not a particular panel for anything but mostly just a practice piece.
Then i made another one trying to keep it matching to the first one, so at this point i might aswell make something so I'm going to weld a strip inbetween them and make a motorbike style fuel tank.
I don't have a bike but maybe it will make my little diesel heater work a bit better
