Dec 19, 2022 16:45:09 GMT
More progress, I'm on a roll. I picked up a sheet of 4mm ply to make the draw bottoms. The front back and sides all got run over the saw to make a grove that the bottom fits into. Then i also did a few extra ones on the sides so i have a couple of groves that will be for any draw dividers if I want them later. Ready to make a start on gluing Oh but before that all the sides need a radius on the top. So i setup the router and tried not to loose any fingers. Now its time for assembly. Plenty of glue everywhere then squared up and stacked with some weight on top to hold them flat while it dries. While they dry i got cracking with the final thing on the main box which is to cut a slight recess in the top for the corner caps i made earlier. Just like this This serves 2 reasons. First it brings the bottom edge of the cap into line with the bottom of the top panel which hides the joint. And secondly they look better just slightly proud of the lid. I remove the bulk with a little router and then finished up very carefully with a chisel. There we go. All 4 fitted and thats the last of the major work on the main box. Back to the draws and the glue has dried nicely. Obviously it has leaked out and expanded in places so bring on the cleanup, a sharp chisel works well for this. Lots of work later they are all cleaned up and sanded Next i need to take a skim off the sides as they are all a tad oversized and then need to cut the grove for the runners. Its getting closer all the time.
Knobs, knobs, knobs. I need some for the draws, and since this is a machinist toolbox it only makes sense that i have done a bit of machining to make it, not to mention i couldnt buy any that would fit. I changed my form tool a bit and am much happier now. Its not quite a one operation tool but its still pretty quick. After a long evening on the lathe i have a stack of them Of course i had to spend a bit of time polishing Looking rather spiffy if i say so myself I have spent a bit of time cutting the runners into the drawer sides. After quite a while of cutting with lots of measurements and fine adjustments to make sure each runner slot was just in the right spot to keep the draw fronts lined up A full stack of drawers are now in place. Next up i decided i need some corner straps. Happy with that design i made another one. Continuing with the escalations i wanted to have a play at wire inlay After messing around with patterns and other things i decided the best option would be to just sign and date the box. So a bit of practice ensued I'm using a 0.5mm cutter in the dremel and tracing the pencil lines. Then a bit of 0.8mm wire hammered into flat and annealed before gluing and tapping into place. Have to use flat because there is no guarantee that round wire would be the same height so when you sand it back the polished face might not all be the same width. This leaves a bit raised above the surface which can be filed and sanded down to give an even polished line. Spent some considerable time writing out my own name until i was perfectly happy with it. And then cut into the front of my box. Really wouldnt want to screw this bit up And the year And after inlay I'm pretty happy with that So only one thing left to do is sanding. Lots and lots of sanding I took the whole box up to 1200 before oil Oiling coming up.
Have to say, your prowess with wood is equal to your prowess with bodywork and mechanicals, Superb work, Nigel
Have to say, your prowess with wood is equal to your prowess with bodywork and mechanicals, Superb work, Nigel And there i was thinking this had come out a damn better than anything else i have ever done.
I'm fairly sure this next bit should come with a censorship warning. I now have a well oiled box. I'm using this stuff, Osmo Clear Satin Oil After 4 coats allowing a day drying between each one the box and drawers are looking rather splendid. Everything together i marked out for the knobs And drilled a load of holes in my shiny box. That went fine and now it is resplendent with its shiny knobs Then its a case of fitting all the extra hardware on The drawers need a liner and since traditionally green beize was the go to thats what i have gone to. Rinse and repeat for the rest of the drawers And now the inner lid. To say I'm chuffed with the result would be an understatement. But wait. Its not finished yet.
jimi
That's turned out even better than I expected, pure class, beautiful wood. Well done, your dad's skills must have rubbed of on you 👍
That's turned out even better than I expected, pure class, beautiful wood. Well done, your dad's skills must have rubbed of on you 👍 It turned out better than i expected too. Somehow i had an image in my head but it didnt come close to this and it didnt hit me until i stood back once it was all together. His skill and knowledge has certainly been a great help while i was building this.
Its almost too nice to use as a toolbox but then again whenever i use it i will smile and thats part of doing all this work. Just needs looking after.
It's beautiful work, the finish is excellent, I know if I'd managed to produce something as good as this I wouldn't "smile" each time I saw it, I'd have a grin from ear to ear !! Nigel
In between the work on my toolbox things have been busy and jobs stacking up. First up an easyish job for a friend at work. He has what can only be described as the fruit of a forbidden relationship between bicycle and wheelbarrow It has a crack in the frame and its easy to see why since all the weight being carried is between the 2 wheels. Sharpie to highlight where the crack is So drilled out the ends and ground out the crack Welded up, Forgive the very bad photo its the only one i have got. And then made a gusset type reinforcement piece. 1.5mm sheet should do it And welded that in Followed by a bit of paint And its on its way back to him for a couple of beer tokens. Then something you might have noticed in the background. There is a large red elephant in my workshop, its not mine but another job for a friend. I think i will start its own thread since there is quite a bit to do.
Jan 10, 2023 12:59:53 GMT
Interesting - how does the steering work on the bi-barrow?
Jan 23, 2023 12:25:47 GMT
It has been the end of an era this weekend. No progress on the car. Instead i have been in the shared workshop. The time has finally come to say goodbye to the pit. It has served us well but i cant say I'm sad to see the back of it. It was always full of water, dark and awkward. The job started with moving everything out and marking the floor Then grabbing the biggest sledge i can find and smashing up a big chunk of the existing floor. Which gets thrown in the bottom of the pit. Followed by some more Then some hardcore goes in and is compacted down. Then repeat, A friend came round to help for a while which was nice to have an extra pair of hands especially for breaking off the top row of blocks from the pit wall. They are hollow blocks filled with concrete so took quite a beating to break off.. Tried with the sds drill but in the end i fired up the slab cutter and ran that through them halfway and finished it off with the sledge. End of saturday i had made good progress and there was only a little bit of pit left. Sunday was alot of work finishing filling in the pit and levelling all the ground off at around 10” deep. Then a few inches of hardcore dropped in to blind it off. Damped and gone over with the whacker again. Then the dpc goes down and called it a night. Everything hurts now so I'm very glad its done. Concrete is getting delivered on wednesday, once thats dry its the beginning of a new age.
Jan 26, 2023 12:13:31 GMT
And wednesday morning dawned dull and cold, we got prepared and removed the workshop doors then bang on time the mixer turned up. He didnt hang about either. Moving faster than a nuns first curry he reversed down and dumped 3 cubic meters of concrete in the hole. We tamped and spread it around but it was a little short. We had worked out our requirements at bang on 3 cubic meters but its hard to get an accurate reading on it all and we couldnt order more without getting a bigger wagon which seemed pointless for an extra 0.1 that we might possibly need. So i got the mixer out and did another 3 small barrow loads by hand. That filled it up nicely. Rehung the doors to keep the wildlife out A few hours later it was floated off and then again after about 12 hours It has come up rather well. Just got 4 weeks of waiting for it to cure now
I think I'm going a bit strange, I thought i had already posted an update. Anyway with the concrete hard enough to walk on i started tidying up the workshop. This included a full cleandown, repaint of walls and roof with new lights. This is before Half the lights didnt work. The roof was stating to fail in places and the walls were filthy, stained and painted. Now the concrete is setting properly i took my grandad down for a drive to Kettering with the trailer. We got a large crate loaded up and headed home. Have to say it was really pushing my little mini digger to its limit trying to lift the crate. But we got it in and unpacked. Yep i bought a 2 post lift. *Happy dance* Unfortunately the concrete still had a week of curing to do so i cracked on with sealing and painting the floor where the lift will go. Along with a small patch on the wall which you will see why later. Soon though with the paint dry and the concrete set it was time to bolt it down. Under supervision of course. It took most of a day to get the posts lined up, all in position along with the electrics and hydraulics connected up. Then the best thing to do is pull my car in and test it out. And then all the other cars just because i can. Onto the green patch on the wall, I probably should have flattened it of a bit but bear with me Decal stuck on reasonably well once i got the heatgun on it. And then a few white coats of paint rollered over it all, before peeling off the vinyl.
jimi
Mar 30, 2023 10:17:58 GMT
Very nice, lift looks good as well
93fxdl
Enter your message here...
Mar 30, 2023 13:53:03 GMT
Very nice looking workspace, now you have cycled the lift a few times, retorque the mounting bolts Ttfn Glenn
jimi
Mar 30, 2023 15:53:56 GMT
With the lift now up in place i could make a start on some work for my grandad, some of you might recall about 2 years ago we did a considerable amount of work on the front end, feel free to flip back a few pages if you don't remember. Ill be honest this lot of work was the final reason for getting a lift. He wants to be able to help out with the work on his own car but cannot get in and out of a pit anymore. This time we are onto the back end and we have a deadline to hit. We have to be done before June as this will be my sister’s wedding car and that happens in June. As you can imagine that pushes a few other projects backwards a little bit. We had a bit of a poke around and decided there really isnt much that needs doing, the arches need some attention along with the ends of the sills but the chassis looked like it was ok and all the suspension will be dropped out for a full strip and rebuild. With that in mind, we dropped the subframe and everything else out. And stripped it down Mostly everything looked good, almost all the bolts came out. We do have 2 that are seized into the shocks and will take a bit of removing. And we found a hole in the lower A frame. Which progressed a bit under more investigation Continuing we pulled the rear bumper off. Which broke the mounts due to steel bolts through aluminium bushings.you would have hoped that they had learned this lesson a long time ago but nope. Its getting more and more common. We also found the bumper skin had been bodged up in the past with a riveted on plate and load of filler And to add to the steel and aluminium issues are these little spacers should be between the 2 steel plates. This is all that was left The reinforcement bar had been busted too I'm guessing at the same time as the skin was and not replaced. Onto the car body then The sill ends are starting to look crusty. And would certainly fail an MOT There is a bit of a blister on the rear drivers chassis leg. And general crust around the arches. Onto sourcing some parts and repair panels that are available.
So in this update i get more proof of my long time belief that none factory undersealer is usually a bad sign. But first some parts have been sourced and collected, We have a good condition A frame A replacement bumper skin, complete with reversing sensors which will be getting connected up. Made a start investigating the sill ends It started out looking reasonable. But quite quickly thinks went crunchy And then I found the fiberglass bog. A bit of wirewheeling and the arch lip has totally disappeared. And also left quite a rusty sill end cap that is going to need replacement. We chopped it out to have a good look down aswell, Cant remove the middle bit as its welded to the sill tube from the back. So cut around that bit. We also noticed where the chassis leg goes up to go over the suspension had a bit if rust in the outer skin So chopped off the outer skin to find more rust So chopped that out too. Luckily thats where it stopped. Then i cleaned up a little bit And made a new section and welded in Then the outer skin welded in and cleaned back aswell That could have been worse, i wonder how the other side looks Yea its just as bad. You know the process New piece Then the next layer And the final piece Have to say it could have been worse. Speaking of worse, Remember this little blister Well i did a bit of grinding And some chopping because if its rotting between the pieces then the full section has to come out including the strengthener plate. Once it was out its a pretty simple job of taking a template and making a new piece. The reinforcement plate is supposed to take a harmonic damper which this car was apparently not fitted with. So it probably wasnt necessary to fit into the new piece but just in case we ever want to fit those bits its better to have the option. So it got sprayed and welded in Cleaned back and a quick spray with the zinc as a temporary coating.
Almost back up to speed of what i have been doing for the past few weeks
Apr 19, 2023 15:20:55 GMT
Some more rust spots i found, in the same area as before but this time above the rear axle. It didnt look like much to begin with, but I'm learning not to ignore a bulge in the panels. Because this is underneath. Same on the drivers side So some more new pieces. Nice and easy again. Welded in, Cleaned back, painted and then the next piece welded in aswell. Onto something a little more tricky. These sill end caps we decided to have a play at making. Its 2mm plate so takes a bit of shaping. I made a wooden form and clamped the steel onto that. This let me fold the edge over to an accurate shape and without distorting the panel. Then i can clamp it back on and chase the step in with a chisel This will fit on nicely. Other side was the same Took about an hour per side to make the form and the panel doing it this way. And the panel comes out just how you want. Its often worth taking time to make a form because it can same a lot of time and pain later on. I'm not welding them on just yet because I'm still waiting on the new outer arch panels to arrive. Next up we started looking at the area at the bottom of the chassis legs and there was a few bits not looking great. So i cracked on will removing that section Its not looking great in there. The other side wasnt any better. Should be a fairly easy piece to make though so i think ill bash on with that next. I see another wooden form coming up.
jimi
Apr 19, 2023 20:01:24 GMT
Your far to good at this Egil 🤣 that's some really nice fabrication 😎😎
