polo6n1600i
All I need is WD40 & Duck tape!
Jan 22, 2020 10:54:17 GMT
The plan for the rest of the week. remove seized central locking kit actuators! Refit the boot lock (currently disconnected) Get the battery back in it & see if it is still good after a recharge (questionable)...
Change the Thermostat & put new coolant in.
I put a jerrycan of 99 fuel in yesterday - so hopefully get her running again later.
The list of small annoying jobs are getting longer:-
Window winders don't clear the door speakers (bought extenders from brickworks!) The radio doesnt work The Amp doesnt get power.... The Sub has been stolen There is a small hole in the battery tray The driver side check strap needs a spot weld on it It needs new wipers Check the lights/bulbs Drivers side seat doesnt tilt without help.. The wheels need some TLC (but there is also a set of 14" Ronal's coming with the rest of the spares next week which I think will really suit the new look that I'm going for...
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
polo6n1600i
New battery on last night - £50 worth of Bosch's finest. £5 worth of fuel out of a can.... Turned the key & NOTHING! Just turning over and no spark - ! Immobiliser acting up? (Clifford 450 with no fob!) Nope! Turned out to be a loose connector to the coil! Pulled apart cleaned contacts & clipped back together full hone - turned the key & it burst in to life! Sounds a little rough currently as its been sat for a while - next service parts!
Jan 25, 2020 10:25:41 GMT
Cool that’s good
polo6n1600i
Jan 25, 2020 12:56:01 GMT
So want to get it MOT'd so I can move on to the bodywork & some more mods!
polo6n1600i
Jan 30, 2020 10:08:24 GMT
Dragging my feet with this due to my shifts - so decided to book this in to the garage for its MOT on the 14th Feb! OH ****! Better get some work done then!
polo6n1600i
So i decided to get stuck in last night at the car again.
A brand new Clifford alarm fob & a set of pairing instructions. Unfortunately the system seems to have a non-standard pin number & refuses to go in to program mode to pair the fob to it..... So they whole system is going to have to come out & i'll need to repair the loom back to standard...
That also means the old central locking kit will need to come out.
The Stereo & hands free kit aren't getting any power, so that's going to have to get sorted out too...
I ran that car last night for a few minutes to just get the oil circulating round the engine. It ran for a few minutes, i then touched the accelerator and the car died. Not sure what the issue is (but i expect it to be spark related - so put a new coil on order)
I think i may have bitten off more than I can chew with the MOT on the 14th, but i'm going to give it a bloody good try!
polo6n1600i
Feb 15, 2020 13:49:13 GMT
So! No Mot on the 14th! The car still refuses to run - the sump was full of fuel/oil. so all drained out - will probably need to be flushed through again. The car is overfueling a lot!
So injectors are away for a rebuild - but I also have an inclination that its the ECU!
I bit the bullet & took the alarm out! 8 hours of work to remove all the wiring and repair the loom correctly! Hard work with it in situ - but I managed it!
polo6n1600i
Feb 24, 2020 16:48:06 GMT
Injectors, new plugs and oil change done & it still fails to start. I've pulled out the engine loom to check the wiring (especially the earth crimp in the looms) and re-wrap the whole thing.
I have spoke with Bedrock Retro VW's in Glasgow - and they might be taking it off me to sort it out if I fail to get it running.
Another couple of people mentioned its probably the ECu as they don't like being jumped started too many times - in the 3 hours it took us to get it out of the garage and on to the tow truck - then up my driveway - this wouldnt surprise me!
Sammo
Club RR Member Number: 103
Feb 24, 2020 17:16:52 GMT
Sounds daft but have you checked all the earths are good? I seem to recall my G40 would struggle to start and run like curse word when the earths got all furry.
Follow Me On Instagram - @parttimecartinkerer
Feb 24, 2020 20:49:28 GMT
No pictures on this page, me makes sad.
polo6n1600i
Feb 25, 2020 20:28:43 GMT
So under the dash this is what I found.... 2 alarm systems, a handsfree kit, a stereo build....
polo6n1600i
Feb 25, 2020 20:29:49 GMT
8 hours work to remove & repair
polo6n1600i
Feb 25, 2020 20:31:35 GMT
ECU/engine loom removed and repaired / re-wrapped with genuine VW loom tape
polo6n1600i
Feb 25, 2020 20:32:21 GMT
Sorry i've been a bit lapse with the pictures....
Still think its the ECU
