...Nik, Richard, Rex( as Abe ), and Ralph the Wonder Llama?
For me, amongst others, that bespoke electrical connectors may be more available than you'd think ( although I haven't tested that theory yet ).
And that it is OK to spend a lot of time making a tool you only plan to use once.
^^ A man after my own heart when it comes to making tools 😂😂
...Nik, Richard, Rex( as Abe ), and Ralph the Wonder Llama? For me, amongst others, that bespoke electrical connectors may be more available than you'd think ( although I haven't tested that theory yet ). And that it is OK to spend a lot of time making a tool you only plan to use once. Got absolutely zero idea what you are on about
Maybe that was a little cryptic...
Nope, still no idea, sorry
Project Binky.
Top notch fabricating disguised as dry humor.
Follow the link, you'll probably enjoy watching it...
Dec 31, 2019 10:48:28 GMT
Who said anything about relying on anybody?
I've learned a lot from the people I've worked for/with, even if sometimes it was how not to do things.
For the last 10 years or so, I go to my own workspace every day, by myself. Which is great, if you are self sufficient...
It is just that with an endless supply of dramatized /scripted "build" shows on TV, it is nice to see some smart well thought out stuff like what these guys do.
To my way of thinking, they undo some of the damage that is done elsewhere. ( And I've picked up a couple of helpful tricks from them as well )
This thread is more of a credit where credit is due kind of thing...
Edit.
The post that this one was a reply to has been deleted.
Dec 31, 2019 10:51:03 GMT
I learn everywhere.
I have very little training, in fact none, but allow everyone to teach me.
This forum is also a good place for just that.
Dec 31, 2019 11:15:36 GMT
I can be pretty self sufficient for work, and generally take a tin-foil hat stance, but if I do that for too long I start to miss things as it all changes so quickly... the most pain free way of not missing things is to use a wholesaler because you bump into other sparks as well as the man behind the counter and reps. But if I do that too often I get the hump with that too, as all the other sparks seem to think their way is the right way etc (they, of course, are wrong because my way is right ) But I’ll go and have a look at Binky, heard it mentioned a few times now. And I have a lot to learn too
jamesd1972
Club RR Member Number: 40
What have you learned from...jamesd1972
@jamesd1972
Club Retro Rides Member 40
Dec 31, 2019 11:23:22 GMT
You can never have too many brackets ? I think the main thing I have learnt is that good builds come from people who probably spend almost as much time measuring / planning / thinking about things as actually doing things. I also learnt I needed a pillar drill with some step drills in my life. Waiting with interest with project Binky, as it stands I don't think they can get in on the road unless they go through the process that blackpopracing has gone through. James
Dec 31, 2019 11:37:24 GMT
What have I learned from? Making mistakes, learn from it and do it again!!
Another good tip measure twice cut once! something I may forget from time to time!
Happy New Year to all, and thanks to all the members for posting as at 55yrs I'm still learning!
What have you learned from...stealthstylz
@stealthstylz
Club Retro Rides Member 174
Dec 31, 2019 11:45:12 GMT
I don't think I've had any "I didn't realise that" moments but it's still enjoyable to watch.
Dec 31, 2019 14:46:49 GMT
Haven’t seen this, heard about it and how good it is, I’ll try to keep up in future! As Ray Mears said a while ago, theres always something new to learn
Dec 31, 2019 16:13:40 GMT
I'm sitting here in my Bad Obsession Motorsports "Make The Noise!" t-shirt, thinking that I learn something in pretty much every episode. Sometimes it's a technique, but more often it's about taking time to think about a solution for a problem nobody knew existed. Brackets can have more than one use, and just because something seems like a daft idea doesn't mean it's not worth doing.
ChrisT
Club RR Member Number: 225
What have you learned from...ChrisT
@christ
Club Retro Rides Member 225
Dec 31, 2019 17:03:00 GMT
As mentioned before - you can never have too many brackets and there's usually a way round something if you put your mind to it (and have the skills/tools/materials needed)
Dec 31, 2019 17:48:31 GMT
As mentioned before - you can never have too many brackets and there's usually a way round something if you put your mind to it (and have the skills/tools/materials needed) And are bloody minded enough😀
