My 2004 Noble M12 GTO 3R, a six+ years project is nearly finished. This is a Noble in name only. Everything under the skin is way over the top. The work has been done by TurboHoses R&D in California. When it goes on the dyno very soon, we estimate 750-800 bhp on pump fuel. Even Lee Noble has been interested. EVERYTHING on this car is bespoke. There is not another Noble like this on the planet.
Below is the build sheet:
ENGINE/ DRIVETRAIN:
• DYNO BEFORE AND AFTER/ LEAKDOWN
• NEW DURATEC 3.0L ENGINE BLOCK w/SLEEVED CYLINDERS
• CYLINDER HEADS REWORKED AS NECESSARY
• CUSTOM ARP HEAD STUDS
• NEW MOTORSPORT PISTONS/ RODS/ CRANKSHAFT
• MAIN BEARING GIRDLE, UPGRADED MAIN/ROD BEARINGS
• THERMAL COATING ON PISTONS, ROD/MAIN BEARINGS
• SINGLE TURBO INSTALLATION Garrett GT35r/ SPOOL VALVE
• 750cc INJECTORS
• LARGER INTERCOOLER
• INCONEL EXHAUST HEADERS
• CERAMIC COATED INCONEL EXHAUST/ “CENTER EXIT” OVAL DUAL EXHAUST PIPES W/ WASTEGATE (Round) TUBE IN BETWEEN EXHAUST PIPES (LIKE FERRARI F40 EXHAUST) EXITING ABOVE DIFFUSER (Creating Blown Diffuser)
• FABRICATED TH INTAKE PLENUM ASSEMBLY
• ENGINE BREATHER SYSTEM W/FABRICATED CATCH CAN
• DRY SUMP OIL SYSTEM
• OIL COOLER UPGRADES, LARGE FRONT/REAR
• ALTERNATOR UNDERDRIVE PULLEY
• POWDER COAT CAM COVERS FERRARI ENGINE RED WRINKLE FINISH
• IGNITION ECU UPGRADE with MULTIPLE MAPS INCORPORATING AIM EVO4 SYSTEM
• REPLACE ANY DAMAGED WIRING
• ARP HS-79 PTFE HOSE w/ HYPALON JACKET for PLUMBING
• AEROQUIP FUEL LINES
• DUAL PASS RADIATOR with ELECTRIC WATER PUMP
• INSTALL COOLING SYSTEM OVERFLOW/ SWIRLPOT (Supplied)
• GETTRAG MMT6 GEARBOX UPGRADE, REPLACE OUTPUT SHAFT and FIFTH GEAR w/ NEW OEM PARTS, BLOCKING RINGS UPGRADE, INSTALL GIRDLES ON TRANSAXLE CASE
• NEW TWIN DISC TILTON CLUTCH, LIGHTENED FLYWHEEL
• UPGRADE CV JOINTS/HD RACE INTERMEDIATE AND OUTER DRIVE SHAFTS, HEAT TREATED AND BLACK OXIDE COATED, PORSCHE UNITS
INTERIOR:
• AIM GT 320 mm STEERING WHEEL with SHIFT LIGHTS / DATA LOGGER SYSTEM (EVO4), SENSORS, with BLUE LED ON/OFF SWITCH ON CENTER STACK (SEE DRAWING)
• PINNED STEERING WHEEL QUICK RELEASE
• MOTHER BOARD/ INTERFACE (between the AIM EVO4 and the ECU) w/LED INDICATOR LIGHTS ON TOP OF STEERING COLUMN TO CONTROL BOOST TABLES, SELECTED WITH A BUTTON ON THE AIM STEERING WHEEL
• INSTALL M400 SHIFTER (supplied, heat insulation sleeves on cables)
• IN - COCKPIT BRAKE BIAS ADJUSTMENT, INSTALL KNOB ON CENTER CONSOLE (SEE DRAWING)
• INSTALL M400 OIL TEMP/PRESSURE GAUGE (supplied), SEE DRAWING
• INSTALL SPA FIRE SYSTEM (supplied), SEE DRAWING FOR NOZZLES AND PULL HANDLE LOCATIONS
• INSTALL AVEO AIRCRAFT BATTERY MASTER KILL SWITCH (supplied), SEE DRAWING
• RELOCATE FUSE/BREAKER PANEL TO REAR BULKHEAD ABOVE FIRE BOTTLE
• REPLACE DASHBOARD CENTER HVAC/ SWITCH/ INDICATOR LIGHTS/ BOOST GAUGE BEZEL (SILVER) WITH A CARBON FIBER BEZEL REPLACEMENT (Same Finish as AIM Steering Wheel)
• REPAIR DRIVER DOOR WINDOW TRACK SEAL
• I WILL SUPPLY DRAWINGS OF FIRE SYSTEM HANDLE/ AIRCRAFT MASTER BATTERY KILL SWITCH, OIL PRESSURE GAUGE, FIRE SYSTEM NOZZLE LOCATIONS, AIM ON/OFF SWITCH, BRAKE BIAS ADJUSTMENT KNOB
• DYNA MAT SOUND DEADENER/ HEAT BARRIER AS NEEDED
• A/C VENT MOD, REPLACE with 2000 – 2006 AUDI TT A/C VENTS
• RECOVER ANY ALCANTERA OR LEATHER AS NEEDED
• TUNNEL COOLING MOD
• CARBON FIBER STEREO COVER
BODY:
• REAR DIFFUSER WITH 6 STRAKES (SEE SUPPLIED DRAWINGS)
• FRONT SPLITTER AND FRONT DIVEPLANES
• FRONT FENDER LOUVRES
• HID HEADLIGHT CONVERSION/ LED TURN SIGNALS
• EURO TAILLIGHT INSTALL (Mondeo MK1 taillights)
• COLD AIR DUCTING INTO CENTER TUNNEL
• REPLACE ALL SILVER HEAT BARRIER WITH GOLD BARRIER IN ENGINE BAY/ NOSE
• REPAIR ANY BLEMISHES IN BODYWORK
• MODIFY/CLOSE BODYWORK AROUND REAR CAGE BRACING
• MODIFY PASSENGER DOORS/INTERIOR PANELS TO CLEAR DOOR BARS
CHASSIS:
• MAIN HOOP BRACING: DIAGONAL ON REAR MAIN HOOP, L/R DIAGONALS ON FRONT HOOP, GUSSETS ON ROLL CAGE, MAIN HOOP REAR BRACES THRU BODY INTO ENGINE BAY, HORIZONTAL BRACE BEHIND SEATS, EXTEND BASE OF MAIN HOOP DOWN THROUGH CHASSIS IN ENGINE BAY, BRACING/ REINFORCEMENT AT BASE OF FRONT HOOP, ADD TUBING AND SHEETMETAL TO STRENGTHEN/ TRIANGULATE CHASSIS IN FOOTWELL AREA, L/R REMOVABLE DOOR BARS, HORIZONTAL SHOULDER HARNESS MOUNTING BAR. THESE MODIFICATIONS AS ILLUSTRATED ON PICTURES THAT I HAVE PROVIDED
• KEVLAR PANEL SCATTERSHIELD BEHIND SEATS (DO NOT COVER)
• FUEL TANK BAFFLES AND INSULATE W/GOLD WRAP
SUSPENSION:
• 6 PISTON FRONT BRAKE UPGRADE/ HATS w/FLOATING ROTORS/ PADS
• WILWOOD COMBINATION BRAKE PROPORTIONING VALVE AND ADJUSTABLE BRAKE BIAS CONTROL FROM INTERIOR
• ADJUSTABLE FRONT SWAY BAR INSTALL
• UPGRADED FRONT UPRIGHTS FOR SWAY BAR INSTALLATION AND CASTER/ CAMBER ADJUSTMENTS
• ADJUSTABLE REAR SUSPENSION TOE LINKS
• NEW STUB AXLES, LONGER WHEEL STUDS
• MODIFIED FRONT/REAR, UPPER/LOWER A-ARMS TO ACCOMMODATE WIDER WHEELS/TIRES
• JONGBLOED 3 PC. WHEELS, BBS STYLE, FRONT: 18x9, REAR:18x11, CENTERS POWDER COATED GUNMETAL GREY
• TIRES: Pilot Sport Cup 2, 265/35/18 Front and 295/30/18 Rear
all tire dia. 25”
ENGINE/ DRIVETRAIN:
• 750cc INJECTORS
INTERIOR:
BODY:
CHASSIS:
SUSPENSION:
all tire dia. 25”
