I purchased this early this year as I wanted a retro but reliable daily. I spent the first week doing a whole bunch of changes and upgrades too it, and since then it has been awesome! I changed the car from a BMW gearbox to a Lexus gearbox so improve the gear ratios, ad fitted a new proper clutch and custom prop etc at the same time. I retrofitted s13 coilovers, converting the rear to 'true coilover' at the same time to massively improve the handling.
The car works flawlessly and has always run well. I have done easily 10k miles in it this year without problem, including driving to Driftland for two days drifting and driving to the south of France.
The car has only done two track days, so has no drift damage, nor has it been crashed. The underside is free of rust and has original underseal as far as I can tell. Bodywork is pretty good, but one of the front wings has some primer on the arch and it split a little from rolling the arch.
I have modified this car so that it is extremely reliable and can withstand all the abuse of the V8 and track days/drifting. I put a lot of thought into the diff and halfshaft setup to ensure it was over-engineered and as strong as possible so that theres no risk of snapping shafts when launching/clutch kicking etc. Heavy duty clutch for the same reason.
I have done several oil changes of engine/gearbox and diff to ensure everything was in good order. No fluid leaks. Never gets too hot, even when drifting.
The car is great fun to drive; extremely rev happy and loads of power for the weight of the car. Will happy drift any corner in 3rd/4th gear in the dry without breaking a sweat.
1986 UK s12
1998 Lexus 1UZFE 4.0l v8 with VVTI
Phoenix custom wiring loom and reworked oem ecu
290bhp
IS200 6 speed gearbox
HKS lightweight MR2 flywheel
Exedy 3 puk sprung clutch
Lexibreak gearbox conversion adapter kit
Custom propshaft with new oem centre bearing
outer trailing arm mounts moved to eliminate all rear camber
Rear subframe, arb and trailing arms polybushed
Front suspension converted to s13, with rose jointed tie rods w/ built in rack spacers and rosejointed adjustable lower wishbones and caster arms
Coilovers
Big brake conversion using nissan z32 4pot front calipers and master cylinder
SSR 16" alloys
rear bolt on 15mm spacers
Custom stainless exhaust with V band joins for easy removal. Two straight through silencers so it sounds awesome but doesnt drone on the motorway and will pass noise regs at all tracks.
Skyline R33 LSD welded by Garage-D with skyline diff outputs
Custom halfshafts to withstand the big power increase. Skyline 5 bolt inner CV joints, Custom made hardened shafts, original S12 outer CV joints
EBC front brake pads, Brand new oem rear pads
1UZ power steering pump paired to nissan rack
Big alloy radiator
Electric fan with temperature operated switch
New thermostat
Heater works as it should
Oil cooler
Remote oil filter kit for good access
Solid steering column bush
Engine dampener
Custom air intake and ramair filter
catch can for rocker breathers
Recaro SR3 drivers seat with custom made seat mount t0 get it as low as possible
Oem drivers seat also included
Battery relocated to the boot
Walbro fuel pump
Adjustable fuel pressure regulator
Digi dash and GPS speedo
Voltage gauge, fuel pressure gauge, built in oil and water temp gauges
Headunit with USB, bluetooth and DAB radio
Resprayed in Kia metallic red
Pop up Sunroof and pop out rear windows
Electric front windows
electric mirrors
Heated rear screen
S13 sideskirts
S12 front splitter
Vertex steering wheel (not pictured)
£5700 ono
1986 UK s12
290bhp
Coilovers
SSR 16" alloys
Big alloy radiator
New thermostat
Oil cooler
Engine dampener
Walbro fuel pump
electric mirrors
Heated rear screen
S13 sideskirts
S12 front splitter
£5700 ono
http://instagr.am/p/B3INOKnHBwN
