Mar 10, 2020 17:07:47 GMT
Check the top and bottom rad hoses when warmed up there should not be a massive temperature difference and give them a squeeze you should be able to feel plenty of water in them, is the water circulating around the heater? if not undo a heater hose and see if you can get more water into the heater pipes When its cold let the pressure out of the cooling system by opening the cap, start the car up and see how quickly the system pressurizes, if its very quick then it may be head gasket
Mar 10, 2020 17:46:40 GMT
Once you have checked the above and that the coolant cap is ok, To rule out headgasket etc put the overflow tube from the coolant reservoir in a clear bottle half full of water, if when it's at normal temperature theres a steady stream of bubbles which increase as you rev the engine theres a good chance you have a problem, you can buy a kit to check the coolant for exhaust gas to be sure.
dikkehemaworst
Club RR Member Number: 16
Mar 20, 2020 10:50:11 GMT
Thanks guys. The samba Has to wait a while, our pub is forced to close, because of corona virus and in an instant our future is a little bit uncertain. Keep you guys posted.
Mar 20, 2020 11:38:57 GMT
Hey mate, hope all will work out for you.
Mar 20, 2020 14:24:54 GMT
Sterkte Kerel!
Mar 20, 2020 14:45:38 GMT
Times are touch for some of us, hope you get through this!
Current: 1983 Volkswagen 1200 Mexico 2021 Kia Niro Hybrid ----- Former: 1989 Volkswagen Jetta 1990 Volkswagen Golf Madison 1996 Volkswagen Golf Wagon Happy Hour 2006 Fiat Panda 100HP 2006 Toyota Avensis Wagon
