Oct 14, 2019 11:26:14 GMT
Google fu is failing and I need another one of these (3mm thick) to fit a passenger side seat belt... I’ve put the feelers out to fabricators but off the shelf is usually quicker, easier to buy, and cheaper. Only results seem to be in USA Cheers in advance
zeberdee
Club RR Member Number: 2
Oct 14, 2019 12:01:35 GMT
Defenders have separate mounting brackets for seatbelts .
I don’t know what size they are though .
Maybe not the most helpful post ever !! 😂
Oct 14, 2019 12:18:05 GMT
I recently purchased a set of new Securon seatbelts for my Minor, which came with some brackets similar to that, which weren't required, so if you get stuck for some, let me know and you can have them for a reasonable price if they're suitable...
jamesd1972
Club RR Member Number: 40
Oct 14, 2019 12:37:16 GMT
I recently purchased a set of new Securon seatbelts for my Minor, which came with some brackets similar to that, which weren't required, so if you get stuck for some, let me know and you can have them for a reasonable price if they're suitable... Yep - I had exactly the same thought as I got some too with the generic Securon belts for the LR. They have been used somewhere though but would be worth looking for or taking up Waxoyling Lyrical 's kind offer. James
Last Edit: Oct 14, 2019 12:37:46 GMT by jamesd1972
Oct 14, 2019 12:42:32 GMT
Funnily enough mine are securon belts - they came with Z brackets and flat plates etc but no L brackets.
defender brackets look possible.
@waxoyling lyrical I'll pm you...
Oct 14, 2019 19:46:57 GMT
OGDB
Oct 14, 2019 20:25:29 GMT
I can laser and have pressed something like this for you if you send me some details. No problem at all.
Great stuff - but Phil have you noticed that the company I pointed you to does a really nice colourful range of belt webbing and make seat belts to your own spec / colours for that finishing touch once you get the Acty back from the paintshop
Last Edit: Oct 15, 2019 8:08:52 GMT by Deleted
Great stuff - but Phil have you noticed that the company I pointed you to does a really nice colourful range of belt webbing and make seat belts to your own spec / colours for that finishing touch once you get the Acty back from the paintshop I did I was actually more impressed by their high polished finish on the metalwork. Maybe one for the future.
