I've got two D12s on the way - one foe me and one for Ethan, sadly ours will be more restrained as I'll be doing replicas of my acty.
Will need to try and look out for wheels that fit these that are smooth disc designs like my image wheels although the standard ones aren't too far off - just the holes being the only difference.
Rich
Club RR Member Number: 160
I've got two D12s on the way - one foe me and one for Ethan, sadly ours will be more restrained as I'll be doing replicas of my acty. Will need to try and look out for wheels that fit these that are smooth disc designs like my image wheels although the standard ones aren't too far off - just the holes being the only difference. Plastic mirror discs with a hole in the middle to fit over the stock wheel hub, with stick on ‘crystals’ detailing for the wheel and split rim bolts? You could cut discs of ‘chrome’ from those universal placca door mirror glasses. Tyres is going to be the hard part. I’m sure there are some low pro tyres that fit these wheels (the RC size is 1.55 iirc)
I've got two D12s on the way - one foe me and one for Ethan, sadly ours will be more restrained as I'll be doing replicas of my acty. Will need to try and look out for wheels that fit these that are smooth disc designs like my image wheels although the standard ones aren't too far off - just the holes being the only difference. Plastic mirror discs with a hole in the middle to fit over the stock wheel hub, with stick on ‘crystals’ detailing for the wheel and split rim bolts? You could cut discs of ‘chrome’ from those universal placca door mirror glasses. Tyres is going to be the hard part. I’m sure there are some low pro tyres that fit these wheels (the RC size is 1.55 iirc) Good call, I could bypass the tyres issue by gluing discs onto the face of the standard wheels but slightly oversized to overlap the front of the tyres, might look odd from front or rear view though.
markbognor
Club RR Member Number: 56
I've got two D12s on the way - one foe me and one for Ethan, sadly ours will be more restrained as I'll be doing replicas of my acty. Will need to try and look out for wheels that fit these that are smooth disc designs like my image wheels although the standard ones aren't too far off - just the holes being the only difference. Plastic mirror discs with a hole in the middle to fit over the stock wheel hub, with stick on ‘crystals’ detailing for the wheel and split rim bolts? You could cut discs of ‘chrome’ from those universal placca door mirror glasses. Tyres is going to be the hard part. I’m sure there are some low pro tyres that fit these wheels (the RC size is 1.55 iirc) Apparently the D12 wheels are moulded and then the tyre is moulded onto it. They look similar to the C34/44 wheel but are smaller - and have that moulded on tyre. I'm going to see if I can track down some foam donuts that are the right sort of size and have some other plans. Wish I had a 3D printer though.
Plastic mirror discs with a hole in the middle to fit over the stock wheel hub, with stick on ‘crystals’ detailing for the wheel and split rim bolts? You could cut discs of ‘chrome’ from those universal placca door mirror glasses. Tyres is going to be the hard part. I’m sure there are some low pro tyres that fit these wheels (the RC size is 1.55 iirc) Apparently the D12 wheels are moulded and then the tyre is moulded onto it. They look similar to the C34/44 wheel but are smaller - and have that moulded on tyre. I'm going to see if I can track down some foam donuts that are the right sort of size and have some other plans. Wish I had a 3D printer though. Could prove trickier then, I'll keep track of what you get up to. I thought you had a 3D printer from your instagram posts?
mylittletony
Club RR Member Number: 84
Sept 9, 2020 11:54:04 GMT
Wish I had a 3D printer though. I know a man who does... I also have CAD capability and some form modelling up scale wheels - although previously for 1/24 builds
markbognor
Sept 9, 2020 14:21:40 GMT
Apparently the D12 wheels are moulded and then the tyre is moulded onto it. They look similar to the C34/44 wheel but are smaller - and have that moulded on tyre. I'm going to see if I can track down some foam donuts that are the right sort of size and have some other plans. Wish I had a 3D printer though. Could prove trickier then, I'll keep track of what you get up to. I thought you had a 3D printer from your instagram posts? It's a CNC router I have - works brilliantly for cutting 2D shapes in the GRP sheet material I use.
markbognor
Sept 9, 2020 14:25:06 GMT
Wish I had a 3D printer though. I know a man who does... I also have CAD capability and some form modelling up scale wheels - although previously for 1/24 builds Thanks, I shall bare this in mind. Pretty sure I can handle the initial drawing - as an STL? - it's the turning that into something that can be printed and printing it where I'm lost. I almost spent the toy car money on a resin printer - but I'm probably having more fun with the actual cars.
Sept 9, 2020 19:32:43 GMT
C44KM'S currently coming in at under £60 on Bangood, and they are on 2-5 day shipping from the Czech warehouse. [£61.43 28% OFF]WPL C44KM Metal Edition Unassembled Kit 1/16 4WD RC Car Off-Road Vehicles with Motor Servo RC Vehicles from Toys Hobbies and Robot on banggood banggood.app.link/dTEZx54CC9 markbognor That is good value - how many slipped into your basket? 😁
markbognor
Sept 11, 2020 7:12:00 GMT
C44KM'S currently coming in at under £60 on Bangood, and they are on 2-5 day shipping from the Czech warehouse. [£61.43 28% OFF]WPL C44KM Metal Edition Unassembled Kit 1/16 4WD RC Car Off-Road Vehicles with Motor Servo RC Vehicles from Toys Hobbies and Robot on banggood banggood.app.link/dTEZx54CC9 markbognor That is good value - how many slipped into your basket? 😁 Might have just bought another C44KM. Though this is for parts - the WPL store only had one metal gear servo available, so this will supply the other I need. I could do with a replacement front axle casing because I drilled the king pins slightly too large on mine. The rear axle will go on the D12 that's coming - I might be able to get the 370 in that too. I might end up ebaying some of the other bits to claw back some pennies.
Sept 17, 2020 8:56:13 GMT
Hey guys just got my mates c34km running well and went to run my 44 together and bum deal.... The v3 sound radios are on the same signal are any of you running multiple v3 radios at once?
Rich
Sept 17, 2020 12:28:23 GMT
Hey guys just got my mates c34km running well and went to run my 44 together and bum deal.... The v3 sound radios are on the same signal are any of you running multiple v3 radios at once? You can run 2 at once, you need to change the jumper pin on one board to the other position.
markbognor
Sept 17, 2020 14:28:28 GMT
Hey guys just got my mates c34km running well and went to run my 44 together and bum deal.... The v3 sound radios are on the same signal are any of you running multiple v3 radios at once? You can run 2 at once, you need to change the jumper pin on one board to the other position. I couldn't even get this to work with my V3's. There's some issue with early boards being released that only work on one channel.
Sept 17, 2020 17:08:20 GMT
You can run 2 at once, you need to change the jumper pin on one board to the other position. I couldn't even get this to work with my V3's. There's some issue with early boards being released that only work on one channel. Just to show my ignorance, but would a different control unit help? I have a spare V3 controller here (and a faulty V3 soundboard).
Sept 17, 2020 17:13:06 GMT
In other news my C44 continues to perform well. It decided to be front wheel drive only last week so a took the back diff apart, cleaned it and put a small washer in to pack the drive pinion out and it seems to have done the trick for now.
My MN99 build is continuing slowly as I wait for bits to arrive (hopefully tomorrow). If it is on interest, I will post some pics up here over the weekend. 🙂
diff
Sept 17, 2020 18:03:16 GMT
I am waiting for a mn90 to arrive at the moment , Banggood say it should have been today .
Sept 17, 2020 22:31:43 GMT
I spoke with Edward he says yeah must be an early 1. Was from wpl rc site and he is sending another:) . My worry is both are from that batch they were purchased about a month apart. My 1st board was faulty so sent a 2nd. Is it the board or the remote?
Oh and thanks guys
Last Edit: Sept 17, 2020 22:32:07 GMT by jethronz
markbognor
Sept 18, 2020 16:10:31 GMT
I spoke with Edward he says yeah must be an early 1. Was from wpl rc site and he is sending another:) . My worry is both are from that batch they were purchased about a month apart. My 1st board was faulty so sent a 2nd. Is it the board or the remote? Oh and thanks guys It's the reciever board that's the issue rather than the transmitter. I had a chat with Edward about mine but when he found out it was through a reseller on BG the conversation petered out.
Sept 18, 2020 17:06:31 GMT
I spoke with Edward he says yeah must be an early 1. Was from wpl rc site and he is sending another:) . My worry is both are from that batch they were purchased about a month apart. My 1st board was faulty so sent a 2nd. Is it the board or the remote? Oh and thanks guys It's the reciever board that's the issue rather than the transmitter. I had a chat with Edward about mine but when he found out it was through a reseller on BG the conversation petered out. markbognor If it is any consolation I talked to him about mine not working, it was purchased direct from WPL and the conversation petered out too 🙄
Sept 18, 2020 19:50:53 GMT
